Sense the future with EzloPi smart capabilities!
In the ever-growing vast field of IoT and home automation, the integration of sensors and actuators plays a crucial role in enhancing the overall security and convenience of smart homes and industries. This project focuses on interfacing the HC-SR501 Passive Infrared (PIR) sensor and a buzzer with the EzloPi device to create an intelligent alarm system for detecting motion and triggering the alarm. The project leverages meshbot automation rules to further extend the capabilities of the smart home ecosystem.
The following components are required:
The wiring diagram for ESP32 30 pins is represented as below:
The following connections are made in order to complete the entire circuit setup:
From ESP32 (30 pins) to PIR sensor module:
From ESP32 (30 pins) to the Buzzer:
Click Connect.
