Sense the future with smart EzloPi integration!
Motion Detection Alerts using IR proximity sensor & EzloPi meshbot
This example demonstrates the interfacing of an IR proximity sensor with the EzloPi device. By interfacing the FC-51 proximity sensor with EzloPi, limitless possibilities open-up for home automation and smart control applications.
By combining the powerful capabilities of the FC-51 proximity sensor with the EzloPi platform, we can detect nearby objects or motion and trigger automated actions in response. Whether we want to automate lighting and appliances or enhance security by creating an intelligent motion detection system based on proximity.
The FC-51 proximity sensor interfaced with EzloPi enhances the smart home automation experience by offering simple setup and variety of customisation options for all, making life easier and more connected than ever. By using the EzloPi automation meshbot feature, users will be able to receive alerts when motion is detected by the sensor.
Welcome to the project demonstration video section. The following video showcases the key aspects of How to create motion alert via Meshbots easily using IR proximity sensor on EzloPi Platform, providing a visual walkthrough of its implementation.
The following components are required for interfacing using the EzloPi device:
- FC-51 Infrared (IR) Proximity sensor.
The wiring diagram for ESP32 is represented as below:
From ESP32 to the IR Proximity sensor:
- Connect the 3V3 pin from ESP32 to the VCC terminal on the FC-51 sensor.
- Connect GND to the GND pin on the sensor module.
- Connect D4 from the ESP32 to the signal (OUT) pin.
4. Interfacing the Proximity sensor using the EzloPi Web Flasher:
Click Connect.
- Set a device name of your choosing. In our case we set it to Proximity Sensor.
- Set the Input GPIO to 4.
- Set Device Subtype to Proximity Sensor.
- Set the Resistor to PULL DOWN.
- Then Click Apply Button.
5. MiOS Web Application
- Here, as you can see in the MiOS mobile app dashboard, we can see the proximity sensor tile which shows that no motion is being detected.
Meshbots
- After clicking on Create new MeshBot you will see this now under Automation MeshBot click on Local.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Proximity Sensor..
- Set Node Type to Device.
- Set the Node to Proximity Sensor.
- Set the Capability to parent_abstract.
- Set the Comparator to Switch.
- Set the Value to True
- Set Controllable Type to Notification.
- Set the User to Your user account but in our case the user account is Tayyab..
- Set the Channels to email,push.
- Set the Subject to Motion Update.
- Set the Message body info to Motion is Detected.
- Here, as you can see in the MiOS web dashboard, we can see the proximity sensor tile which shows that the motion is detected by the sensor therefore an email is sent to the user to alert about any detected motion or suspicious activity.
6. MiOS App
