Smart protection with EzloPi
Monitor voltages and ambient temperatures
This project involves monitoring voltages and ambient temperature by interfacing a voltage sensor module and a DS18B20 temperature sensor with the EzloPi device. The voltage sensor measures the electrical potential of a source, enabling real-time voltage monitoring, while the DS18B20 captures precise ambient temperature readings. Both sensors are integrated with EzloPi for seamless data acquisition and display. This setup is ideal for applications like environmental monitoring, equipment diagnostics, and smart home automation. The project demonstrates the versatility of the EzloPi device in managing multiple sensor types efficiently.
- Voltage sensor module.
- DS18B20 Temperature and humidity module.
- LED with 120 Ohm Resistance.
From ESP32 to the Voltage sensor:
| ESP32 | Voltage sensor |
| VIN | +(VCC) |
| GND | -(GND) |
| D33 | S(Signal) |
From ESP32 to the DS18B20:
| ESP32 | DS18B20 |
| 3V3 | VIN |
| GND | GND |
| D15 | S(Signal) |
From Solid State Relay to LED & Resistor:
| ESP32 | LED | Resistor |
| D4 | - | Terminal 1 |
| GND | Cathode | - |
| - | Anode | Terminal 2 |
4. Interfacing the Voltage Sensor and DS18B20 with LED using the EzloPi Web Flasher
Click Connect
- An Analog Input window will be opened for inputting the following parameters:
- Set the Device name of your choosing. In our case, we set it to the Voltage Sensor.
- Set the Device Subtype to Shunt Voltmeter.
- Set the ADC Input pin GPIO to 14.
- Set the Resolution to 10-bit.
- Then Click Apply Button.
- In the Device Configuration, tab click on One Wire.
- A One Wire window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to the DS18B20.
- Set the GPIO to 15.
- Set the Device Subtype to DS18B20 Temperature Sensor.
- In the Device Configuration, tab click on Digital Output
- A Digital Output window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to the LED.
- Set Device Subtype to LED.
- Set OUT GPIO to 4.
- Set Resistor to PULL UP.
- Now Click the Apply button.
5. MiOS Web Dashboard
- In the MiOS web dashboard, you will be able to see the tiles for the voltage sensor, DS18B20 module and LED. The LED tile will indicate the status of the voltage sensor and DS18B20 depending on what the conditions are set in the meshbot.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test014.
- Set Node Type to Device.
- Set the Node to Voltage Sensor.
- Set the Capability to parent_abstract.
- Set the Variables to uuid.
- Set the Comparator to Greater (>).
- Set the Value to 3.70.
- Add another device in the Trigger section by pressing the Add Trigger button.
- Set the Node to DS18B20.
- Set the Value to 30.0.
- Set the Controllable to LED.
- Set the Capability to power_command.
- Set the Value Type to set.
- Set the Value to true.
- Now Click the Save button.
- Now, on the MiOS web dashboard, you can see that the voltage sensor is showing random value means source is not connected to it whereas DS18B20 also showing normal temperature value so the LED remains OFF because of the rules we have set in meshbot.
- Here, we can see that now the voltage sensor detects some voltages and also there is an increased value detected by DS18B20 therefore the LED is turned ON because of the conditions we have set in the meshbot.
6. MiOS App
- On the MiOS mobile dashboard, you can see that the voltage sensor is showing random value means source is not connected to it whereas DS18B20 also showing normal temperature value so the LED remains OFF because of the rules we have set in meshbot.
