Mini DC Motor
The project demonstrates on interfacing the B366 Mini DC Motor with the EzloPi device, combining the power of a compact motor with the flexibility and control capabilities of the EzloPi platform. This integration opens up various possibilities for automation, robotics, and smart home applications.
We can integrate the motor control system into existing smart home or IoT ecosystems if applicable and also create automation routines to trigger motor actions based on specific events or conditions.
ESP32 as an EzloPi smart device.
B366 Mini DC Motor.
From ESP32 (30 pins) to the DC Motor:
- Connect the GND from the ESP32 to the one wire of the DC Motor.
- Connect the D15 pin from the ESP32 to the other wire of the DC Motor.
4. Interfacing the DC Motor using EzloPi Web Flasher
1. Set up your device/hardware by visiting config.ezlopi.com/
Click Connect.
- Set a Device Name of your choosing. In our case, we set it to DC Motor.
- Set Device Subtype to Relay.
- Set the OUT GPIO to 15.
- Set the Resistor to PULL UP
- Now Click the Apply button.
5. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. We can control the ON/OFF state of the DC motor remotely by using the MiOS platform.
6. MiOS Web Application
- After opening the MiOS web dashboard, you will be able to see the tile of your connected device. We can control the ON/OFF state of the DC motor remotely by using the MiOS platform.
