Methane and smoke detection system with visual and audible alarm
The following project is a safety solution designed to monitor and alert users to the presence of hazardous gases. Utilizing the MQ4 methane gas sensor and MQ2 LPG gas sensor, the system detects methane, LPG and smoke in the environment. When dangerous gas levels are identified, a buzzer provides an audible alarm, and an LED offers a visual indication, ensuring timely alerts. The sensors and components are seamlessly interfaced with the EzloPi device for real-time monitoring and control. This system is ideal for homes, industrial spaces, and enclosed areas, enhancing safety by preventing potential gas-related hazards.
  • MQ4 Methane gas sensor with two 1K Ohms resistors.
  • MQ2 LPG gas sensor with two 1K Ohms resistors.
  • LED with 100 Ohms resistor.
  • MH-FMD buzzer
From ESP32 to the MQ4 gas sensor:
ESP32MQ4Resistor 1Resistor 2
VCCVIN--
GNDGND--
D13D0--
-A0Terminal 1-
D33-Terminal 2Terminal 1
GND--Terminal 2
From ESP32 to the MQ2 gas sensor:
VCCVIN--
GNDGND--
D12D0--
-A0Terminal 1-
D32-Terminal 2Terminal 1
GND--Terminal 2
From ESP32 to the Buzzer::
ESP32LED2
3V3VCC
GNDGND
D15I/O
From ESP32 to the LED & Resistor:
ESP32LEDResistor
D4-Terminal 1
GNDCathode-
-AnodeTerminal 2
4. Interfacing the Methane, LPG gas sensor and buzzer using the EzloPi Web Flasher::
Click Connect
  1. Other window will be opened for inputting the following parameters:
  • Set a Device name of your choosing. In our case, we set it to MQ4.
  • Set Device subtype to MQ4 Methane Gas Sensor.
  • Tick mark the boxes of GPIO 1 & GPIO 2.
  • Set the GPIO 1 to 13.
  • Set the GPIO 2 to 33.
  • Then Click Apply Button.
  1. Again, In the Device Configuration, tab click on Other
  • Set a Device name of your choosing. In our case, we set it to MQ2.
  • Set Device subtype to MQ2 LPG Gas Sensor.
  • Check mark the boxes of GPIO 1 & GPIO 2.
  • Set the GPIO 1 to 12.
  • Set the GPIO 2 to 32.
  1. Again, In the Device Configuration, tab click on Digital Output.
  1. A Digital Output window will be opened for inputting the following parameters:
  • Set a Device name of your choosing. In our case, we set it to the Buzzer.
  • Set Device Subtype to LED.
  • Set the OUT GPIO to 15.
  • Set the Resistor to PULL UP.
  • Set a Device name of your choosing. In our case, we set it to the LED.
  • Set the OUT GPIO to 4.
  • Now press the Flash Device Button.
5. MiOS Web Dashboard
  1. On the MiOS web dashboard, you will be able to see the tiles of connected devices. In our case, we have MQ4 and MQ2 gas sensors for gas detection in the mines whereas buzzer and LEDs are used for alert or indication.
MeshBots:
  1. On the left side of the screen under Automation, click on MeshBots.
  2. On meshbot screen, click on Create new MeshBot button present on the top right corner of the screen.
  3. After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on EzloPi.
  1. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test016.
  1. Set these things in TRIGGER section:
  • Set Node Type to Device.
  • Set the Node to MQ4_digi.
  • Set the Capability to Gas alarm.
  • Set the Armed State to any.
  • Set the value to combustible_gas_detected.
  1. Set these values in the TRUE part of the ACTION section:
  • Set Controllable Type to Device.
  • Set the Controllable to Buzzer.
  • Set the Capability to switch.
  • Set the Value to true.
  1. Set these values in the FALSE part of the ACTION section:
  • Set the Value to false.
  • Now Click the Save button.
  1. Again Click on Create new Meshbot and under Automation MeshBot click on Cloud.
  2. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test017.
  • Set the Node to MQ2_digi.
  1. Set these values in the TRUE part of the ACTION section.
  • Set the Controllable to LED.
  1. Set these values in the FALSE part of the ACTION section.
  1. Here, you can see your saved MeshBot. Now click on Dashboard.
  1. Now in the MiOS web dashboard, we can see that when there is a small amount of gas detection by both of our gas sensors, there is no triggering for the buzzer and LED. These logics are set in the meshbot.
  1. Here in the above picture, it shows that when the gas concentration detected becomes very high for both gas sensors then both the buzzer and LED turns ON because of our meshbot settings. We have set the buzzer alert for MQ4 whereas LED alert is for MQ2 gas sensor as you can see in the meshbot above.
6. MiOS App
Google PlayApple App Store
  1. On the MiOS mobile dashboard, we can see that when there is a small amount of gas detection by both of our gas sensors, there is no triggering for the buzzer and LED. These logics are set in the meshbot.
Buy Components
