Liquid flow monitoring with EzloPi!
Measuring water flow using YF-S201 Flow meter
This project aims to integrate a YF-S201 flow meter with the EzloPi device to enable accurate monitoring and control of liquid flow in various applications. By interfacing these two components, users can track flow rates in real-time and implement automated actions based on predefined thresholds or patterns using meshbots. Integration of the EzloPi device with the YF-S201 flow meter allows for precise measurement of liquid flow, enhancing efficiency and enabling intelligent decision-making.
Through this project, users can leverage the combined capabilities of both devices to optimize processes, detect anomalies, and improve overall system performance. The seamless integration of the YF-S201 flow meter with the EzloPi device offers a versatile solution suitable for a wide range of monitoring applications.
Welcome to the project demonstration video section. The following video showcases the key aspects of Measuring water flow using YF-S201 Flow meter, providing a visual walkthrough of its implementation.
- YF-S201 Flow Meter.
From ESP32 to YF-S201 Flowmeter:
ESP32 | YF-S201 |
VIN | VCC |
GND | GND |
D5 | Signal |
4. Interfacing the Flow meter with the EzloPi Web Flasher:
Click Connect
- If you are new to this and it's your first time configuring, select Create new Device ID. Click on the Configure Wifi button. Enter Wifi SSID and Wifi Password.
- In the Device Configuration, tab click on PWM.
- A PWM window will open for inputting the following parameters:
- Set a Device Name of your choosing. In our case, we set it to Flowmeter.
- Set Device Subtype to YFS201 Flowmeter.
- Set the PWM_GPIO to 5.
- Set the Frequency from the given Frequency slider.
- Set the Resolution to 8 bits.
- Set the Duty Cycle from the given Duty Cycle slider.
- Now Click the Apply button.
5. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. As seen above, the flow meter tile is displayed which shows how much water is flowing.
5. MiOS Web Dashboard
