The following example showcases how we can interface a button and LED with the EzloPi device and use it as a blink LED. This setup allows you to use a button to control the operational state of the LED, providing visible feedback in response to a button press. We can expand upon this foundation to create more complex and interactive applications with our EzloPi device and MiOS smart application.
Welcome to the project demonstration video section. The following video showcases the key aspects of Make LED blink using EzloPi meshbot, providing a visual walkthrough of its implementation.
- Button
- LED with a current limiting resistor of 82 Ohms.
From ESP32(30 pins) to Button:
4. Interfacing the button and LED using the EzloPi Web Flasher
Click Connect.
- Set a device name of your choosing. In our case, we set it to Button.
- Set Device subtype to Digital In Switch/ Button/ Key.
- Set OUT GPIO to 15.
- Set the default value to LOW.
- Again, In the Device Configuration, tab click on Digital Output.
- Set a device name of your choosing. In our case, we set it to LED.
- Set Device subtype to LED.
- Set OUT GPIO to 2.
- Set the Default value to LOW.
- Then Click Apply Button.
5. MiOS Web Dashboard
- As seen in the MiOS web dashboard above, the button and LED status tiles are not ON moment.
MeshBots:
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Blink_LED.
- Set these values in TRIGGER section:
- Set Node Type to Device.
- Set the Node to Button.
- Set the Capability to Switch.
- Set the value to True.
- Set Controllable Type to LED.
- Set the Capability to switch.
- Set the value to true.
- Add one more Action by clicking the Add Action button.
- Set the value to false.
- Set action to Delay and Set the Delay to 2 Seconds.
- As we are executing actions sequentially and in a loop so we have to change the action sequence which is given in the top right corner in the Action tab, Change the option to Execute actions sequentially as long as previous action succeeds.
- As seen in the MiOS web dashboard above, the blinking LED function can be seen which we have implemented through the meshbot. In the first image, we have turned on the button and LED turns on. In the second image, the button is still on but the LED is turned off because of the blink function which repeats itself after every 2 seconds as the rules we have set in the meshbot.
5. MiOS App
- After opening the mobile dashboard, you will be able to see the tile of your connected device.
- As we have seen above in the MIOS mobile dashboard, the blink LED function is successfully implemented according to meshbot rules.
