This project aims to integrate the KY-024 Hall Effect sensor with the EzloPi device, enhancing its functionality for detecting magnetic fields. The KY-024 sensor employs the Hall Effect principle to measure magnetic fields, making it suitable for various applications like proximity sensing and speed detection. By interfacing this sensor with the EzloPi, we can leverage its capabilities for smart home automation, security systems, and industrial monitoring.
Through this integration, users can monitor magnetic field changes remotely and trigger predefined actions based on detected magnetic field variations. Ultimately, this project aims to provide users with a versatile solution for incorporating magnetic field sensing into their electronics or DIY projects and IoT setups, enhancing automation and control capabilities.
Welcome to the project demonstration video section. The following video showcases the key aspects of How to utilize the KY 024 Hall effect sensor and an EzloPi for accurate magnetic field detection, providing a visual walkthrough of its implementation.
- Ky-024 Hall Effect sensor.
- A small magnet.
From ESP32 to KY-024:
4. Interfacing the Hall Effect Sensor with EzloPi Web Flasher:
Click Connect.
- The Other window will open for inputting the following parameters:
- Set a device name of your choosing. In our case, we set it to the Hall Effect Sensor.
- Set Device Subtype to Internal Hall Effect Sensor.
- Check the GPIO 1 box and set it to 15.
- Then Click Apply Button.
5. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device.
- As you can see in the MiOS mobile dashboard, we can see the Hall effect sensor tile. When the KY-024 detects a magnetic field or object such as a small magnet, the tile will display the “Closed” message as shown in the above image.
- Similarly, when the KY-024 does not detect any magnetic field or object, the tile will display the “Open” message as depicted in the above image.
6. MiOS Web Application
- As seen in the MiOS web dashboard above, the Hall effect sensor tile is visible with the message “Closed” which means that the KY-024 hall effect sensor is detecting magnetic fields or a magnetic object is placed near the ESP32-based EzloPi device.
