Endless possibilities with EzloPi!
Magnetic door sensor with buzzer alarm
This project involves interfacing an MC-38 magnetic door switch and an MH-FMG buzzer with the EzloPi device to create a simple door security system. The MC-38 switch detects door status (open/closed) by sensing the magnetic field between its components. When the door opens, breaking the magnetic field, the EzloPi device reads this change and activates the MH-FMG buzzer, providing an audible alert. The system is programmed using the EzloPi device to handle input from the MC-38 switch and control the MH-FMG buzzer accordingly. This setup enhances home security by providing real-time notifications of door status changes, which can also be monitored remotely using the MiOS smart application.
Welcome to the project demonstration video section. The following video showcases the key aspects of Magnetic door sensor with buzzer alarm, providing a visual walkthrough of its implementation.
- MC-38 Magnetic door switch.
- MH-FMG buzzer
From ESP32 to the MC-38 Magnetic door switch:
ESP32 | MC-38 Magnetic door switch |
GND | G (GND) |
D5 | +ve |
From ESP32 to the MH-FMG buzzer:
ESP32 | MH-FMG buzzer |
GND | G (GND) |
D4 | +ve |
4. Interfacing the MC-38 Magnetic Switch module and buzzer using the EzloPi Web Flasher:
Click Connect
- Set a device name of your choosing. In our case, we set it to the Door sensor.
- Set the INPUT GPIO input pin to 4.
- Set Device Subtype to Reed Switch.
- Set Default Value to LOW.
- Now Click the Apply button.
- Set a Device name of your choosing. In our case, we set it to Buzzer Alarm.
- Set Device Subtype to LED.
- Set the OUT GPIO input pin to 5.
5. MiOS Web Dashboard
- As seen in the MiOS web dashboard above, the door sensor and buzzer alarm tiles are visible.
MeshBots:
- After clicking on Create new MeshBot you will see new options, click on EzloPi.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test001.
- Set these values in TRIGGER section:
- Set Node Type to Device.
- Set the Node to Door Sensor.
- Set the Capability to Dw state.
- Set the value to dw_is_opened.
- Set these values in the True part of the ACTION section.
- Set Controllable Type to Buzzer Alarm.
- Set the Capability to Switch.
- Set the value to true.
- Here, it can be seen that the door sensor tile turns on which indicates that it is detecting some magnetic field, then the Buzzer Alarm gets triggered turns on because of the rules we have set in the meshbot.
6. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. We can see the Door sensor switch tile and Buzzer alarm tile.
- Here, it can be seen that the door Sensor tile turns on which indicates that it is detecting some magnetic field, then the buzzer alarm also turns on because of the rules we have set in the meshbot.
