In this innovative Magnetic Door Sensor Circuit we will be Leveraging the power of EzloPi smart device by interfacing integrated magnetic door sensor, this circuit will ensure reliable detection of door status. Whether you're monitoring entrances for security purposes or creating an automated IoT ecosystem, our circuit delivers real-time feedback. With EzloPi smart devices you can trust in the efficiency and intelligence of our Magnetic Door Sensor Circuit for a heightened level of control and awareness in your spaces.
Welcome to the project demonstration video section. The following video showcases the key aspects of How to work with Magnetic Door Sensor Indicator on EzloPi platform, providing a visual walkthrough of its implementation.
- MC-38 Magnetic Door Switch.
The wiring diagram of ESP32 is represented as follows:
From ESP32 to the MC-38 Magnetic Door Switch:
- Connect the 3V3 of the ESP32 with any one wire of the MC-38 Magnetic Door Switch.
- Connect the D4 pin of the ESP32 to another wire of MC-38 Magnetic Door Switch.
4.Interfacing the MC-38 Magnetic Door Switch module using the EzloPi Web Flasher:
Click Connect.
- Set a device name of your choosing. In our case, we set it to Door Sensor
- Set the INPUT GPIO input pin to 4.
- Set device Subtype to Reed Switch.
- Set the Resistor Setting to PULL DOWN.
- Then Click Apply Button.
5. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device.
- As you can see in the example given above, we can see the Door Sensor tile. It shows a “Closed” message on the tile as the sensor is detecting that the door is closed.
- Similarly, It shows an “Open” message on the tile when the sensor detects no magnetic fields.
6. MiOS Web Application
- Now, you will see a tile labeled as Reed switch on the MiOS web application dashboard. Currently, As you can see above, It shows a “Closed” message on the tile as the sensor is detecting that the door is closed.
