The Hall effect sensor is a transducer that detects changes in magnetic fields. When a magnetic field is present, it generates a voltage proportional to the strength of the field. This voltage can be used to determine the presence, strength, or orientation of a magnet or magnetic field source.
The EzloPi device based on ESP32 comes equipped with a built-in Hall effect sensor, which can prove to be a valuable component for detecting magnetic fields and various applications like proximity sensing, rotation measurement, and more.
Welcome to the project demonstration video section. The following video showcases the key aspects of Magnet Detection and email notification based on ESP32 Internal Hall Effect Sensor on EzloPi, providing a visual walkthrough of its implementation.
- A small magnet.
Note: There is no need for connections because we are using the built-in Hall effect sensor.
4. Interfacing the Built-In Hall Effect Sensor with EzloPi Web Flasher:
Click Connect.
    - If you are new to this and it's your first time configuring, select Create new Device ID.  Enter Wifi SSID and Wifi Password.
    - The Other window will open for inputting the following parameters:
    - Set a device name of your choosing. In our case, we set it to the Hall Effect Sensor.
- Set Device Subtype to Internal Hall Effect Sensor.
- Leave the GPIO settings without making any changes. As we are using the built-in Hall effect sensor, we don’t have to set any GPIO.
- Now Click the Apply button.
5. MiOS Web Application
    - As seen in the MiOS web dashboard above, the Hall effect sensor tile is visible with the message “Closed” which means that the built-in hall effect sensor is detecting magnetic fields or a magnetic object is placed near the ESP32 based EzloPi device.
- As seen in the MiOS web dashboard above, the Hall effect sensor tile is visible with the message “Open” which means that the built-in hall effect sensor is not detecting magnetic fields.
MeshBots:
- After clicking on Create new MeshBot you will see new options, now under Notification MeshBot click on Create.
    - On the next screen you will see that we can create a name of our choosing, in this case we write it as Test001.
    - In the trigger tap you can set the TRIGGER for your device and in the ACTION tab you can set the action to be performed based on the trigger which you have created.
    - Set these values in TRIGGER section:
- Set Node Type to Device.
- Set the Node to Hall Effect Sensor.
- Set the Capability to contact_sensor.
- Set the variables to status.
- Set the Comparator to On change.
    - Set these values in ACTION section.
    - Set Controllable Type to Notification.
- Set the User to Your user account.
- Set the Channels to email,push.
- Set the Subject to Magnetic Locks Update.
- Write the suitable Message body that you want to receive in your email. As you can see, we write, Magnetic field has changed.
    - As seen in the MiOS web dashboard above, the Hall effect sensor tile is visible with the message “Closed” which means that the built-in hall effect sensor is detecting magnetic fields.
    - As we can see we have received email through Meshbot when a magnet is placed near ESP32 based EzloPi device.
6. MiOS App
    - After opening the dashboard, you will be able to see the tile of your connected device.
- When the ESP32 does not detect any magnetic field or object, the tile will display the “Open” message as depicted in the above image.
- When the ESP32 detects a magnetic field or object, such as a little magnet, we receive an email via meshbot, as shown in the MiOS mobile dashboard.
