Smart projects to make life easier
Liquid dispensing system
The liquid dispensing system integrates a KY-025 reed switch module and a float switch with the EzloPi device for efficient and automated fluid management. The KY-025 module detects the presence or movement of magnetic fields, enabling precise control of dispensing operations, while the float switch monitors liquid levels to prevent overflows or shortages. This setup ensures accurate liquid delivery, making it ideal for applications like beverage dispensers, chemical handling, or irrigation systems. The EzloPi device serves as the central hub, providing seamless operation and monitoring, enhancing reliability and automation.
- KY-025 Reed switch module.
- Float switch.
From ESP32 to the KY-025:
| ESP32 | KY-025 |
| 3V3 | +(VCC) |
| GND | G(GND) |
| D15 | D0 |
From ESP32 to the Float Switch:
| ESP32 | Float Switch |
| GND | Terminal 1 |
| D13 | Terminal 2 |
4. Interfacing the Reed Switch Module & Float Switch using the EzloPi Web Flasher
Click Connect
- If you are new to this and it's your first time configuring, select Create new Device ID. Click on the Configure Wifi button. Enter Wifi SSID and Wifi Password.
- A Digital Input window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to Reed Switch.
- Set the INPUT GPIO to 15.
- Set Device Subtype to Reed Switch.
- Set the Resistor to PULL DOWN.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on Digital Input
- Set a Device name of your choosing. In our case, we set it to Float Switch.
- Set the INPUT GPIO to 4.
- Set Device Subtype to Float Switch.
5. MiOS App
- After opening the MIOS mobile app, you will be able to see the tiles of your connected devices. Here, we have the Reed switch module and Float switch and by utilizing the output of these sensors we can easily know the situation and implement the liquid dispensing situation. In the picture, the scenario is that when the Reed switch is open, the liquid will not dispense until the reed switch is closed while float switch monitors the liquid level whether it is enough or its required to fill the liquid.
- Now, in the above picture, we can see that when liquid level gets low then the reed switch gets closed to deliver the liquid.
6. MiOS Web Dashboard
- After opening the MIOS web dashboard, you will be able to see the tiles of your connected devices. Here, we have the Reed switch module and Float switch and by utilizing the output of these sensors we can easily know the situation and implement the liquid dispensing situation. In the picture, the scenario is that when the Reed switch is open, the liquid will not dispense until the reed switch is closed while the float switch monitors the liquid level whether it is enough or its required to fill the liquid.
