Transform motion into smart innovation!
Line detection using KY-33 line sensor
This project aims to integrate the KY-033 line tracking sensor with the EzloPi device for efficient detection capabilities. By connecting the KY-033 sensor to the EzloPi device, the system will be able to detect and track lines on surfaces, which will enable automated navigation for robots or vehicles. The EzloPi device interprets sensor inputs to accurately follow paths or lines differentiating between black and white colors, making it suitable for various applications such as autonomous vehicles, industrial automation, or educational robotics. The ultimate goal is to create a reliable and versatile solution for line tracking using readily available hardware and open-source EzloPi platform.
Welcome to the project demonstration video section. The following video showcases the key aspects of Line detection using KY-33 line sensor, providing a visual walkthrough of its implementation.
- KY-033 Line tracking sensor module.
From ESP32 to KY-033:
ESP32 | KY-033 |
3V3 | VCC |
GND | GND |
D4 | OUT |
4. Interfacing the Line tracking sensor using the EzloPi Web Flasher
Click Connect
- Set a device name of your choosing. In our case we set it to KY-033 Line Tracking Sensor.
- Set the Input GPIO to 4.
- Set Device Subtype to IR Proximity Sensor.
- Set the Resistor to PULL DOWN.
- Now, Click the Apply button.
5. MiOS App
- After opening the dashboard, you will be able to see the tile of your connected device. As you can see in the MiOS mobile app dashboard, we can see the line sensor tile which lights up when any black line is detected by the sensor. For now, nothing is being detected.
- Here, it can be seen that the line sensor tile lit up which indicates that it is detecting black line.
6. MiOS Web Dashboard
- As you can see in the MiOS web dashboard, we can see the line sensor tile which turns on when any black line is detected by the sensor. For now, nothing is being detected.
