Monitor Your Smart World with EzloPi!
Light Monitoring with alerts using LDR analog sensor
The following project involves interfacing an LDR sensor module with the EzloPi device for real-time light monitoring and alerts the user by utilizing a buzzer. The sensor captures ambient light and provides analog values, allowing real-time tracking of light intensity. This integration enables applications such as automated lighting control, energy efficiency optimization, or security systems based on environmental light conditions. The EzloPi device offers a unique solution for smart home, office or industrial automation setups.
Welcome to the project demonstration video section. The following video showcases the key aspects of Light Monitoring with alerts using LDR analog sensor, providing a visual walkthrough of its implementation.
- LM393 Photoresistor module.
- MH-FMD Buzzer
From ESP32 to LDR module:
| ESP32 | LDR |
| 3V3 | VCC |
| GND | GND |
| D33 | A0 |
From ESP32 to Buzzer:
| ESP32 | Buzzer |
| 3V3 | VCC |
| GND | GND |
| D33 | A0 |
4. Interfacing the LDR sensor & Buzzer module using EzloPi Web Flasher
Click Connect
- Set a Device name of your choosing. In our case, we set it to LDR.
- Set Device subtype to LDR Sensor (Analog).
- Set OUT GPIO to 33.
- Set Resolution to 10-bit.
- Then Click Apply Button.
- Set a Device name of your choosing. In our case, we set it to Buzzer Alarm.
- Set Device subtype to LED.
- Set OUT GPIO to 4.
- Set Resistor to PULL UP.
- Set Default value to LOW.
5. MiOS Web Dashboard
- After opening the MiOS web dashboard, you will be able to see the tile of your connected devices. For now, the LDR tile is showing light intensity value and the buzzer tile is also visible which shows its current state as OFF.
MeshBots
- After clicking on Create new MeshBot you will see new options, click on EzloPi.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test001.
- Set these values in TRIGGER section:
- Set Node Type to Device.
- Set the Node to LDR.
- Set the Capability to Light alarm.
- Set the value to no_light.
- Set these values in the True part of the ACTION section.
- Set Controllable Type to Buzzer Alarm.
- Set the Capability to Switch.
- Set the value to true.
- Set these values in the False part of the ACTION section.
- Set the value to false.
- Now, it can be seen that when the intensity of light incident on the LDR sensor is very low, the buzzer alarm turns on because of the rules we have set in the meshbot.
6. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected devices. For now, the LDR tile is showing light intensity value and the buzzer tile is also visible which shows its current state as OFF.
