Easily monitor your smart home lighting!
Light intensity notification with EzloPi MeshBots
The goal of this project is to interface the LM393 LDR (Light Dependent Resistor) module with the EzloPi device to monitor changes in light intensity. Upon detecting a decrease in light, the system will use the EzloPi meshbot to send an email notification to the user. This project provides a convenient way to stay informed about variations in ambient light conditions which can provide insights about your smart home lighting conditions. Also users can monitor their smart home lighting intensity remotely by using the MiOS application.
- LM393 photo-resistive LDR module.
From ESP32 to LDR module:
- Connect 3V3 from the ESP32 to the VCC of the module.
- Connect GND from the ESP32 to the GND pin on the module.
- Connect D5 from the ESP32 to the D0 Pin on the LDR module.
From ESP32 to the LED:
- Connect the D5 pin from the ESP32 to the LED anode (long leg) through a current limiting resistor of 82 Ohms.
- Connect the GND to the cathode (short leg) of the LED.
3. Interfacing the LDR sensor module using the EzloPi Web Flasher
Click Connect.
- A window will open for inputting the following parameters:
- Set a device name of your choosing. In our case, we set it to LDR.
- Set OUT GPIO to 5.
- Set the default value to LOW.
- Then click Apply Button.
4. MiOS Web Application
- Now, on the MiOS web dashboard, you will be able to see the tile for the touch sensor and the buzzer. The tile will indicate the status of the buzzer depending on the touch sensor being operated.
Meshbots
- After clicking on Create new MeshBot you will see this now under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as LDR.
- Set Node Type to Device.
- Set the Node to LDR.
- Set the Capability to power.
- Set the variables to status.
- Set the Comparator to Equal(==).
- Set the value to false.
- Set Controllable Type to Notification.
- Set the User to Your user account but in our case the user account is Tayyab.
- Set the Channels to email, push.
- Set the Subject to Light intensity Update.
- Set the Message body info to Light Intensity has been decreased.
- When the light incident on the LDR module is blocked, the LDR tile will turn blue and no notification is sent to the user.
- When the light is blocked again, the notification is sent to the user’s email.
5. MiOS App
- Now, on the MiOS mobile dashboard, you will be able to see the tile for the touch sensor and the buzzer. Both will be functioning according to rules we have set in meshbot.
