LED Control using ESP32 WEMOS D1 R32
The ESP32 is an incredibly versatile and powerful microcontroller with built-in Wi-Fi and Bluetooth capabilities that can be seamlessly integrated with various compatible boards and components, expanding its capabilities and applications, making it an excellent choice in the world of electronics and IoT. There are many development boards based on the ESP32 MCU available on the market today in the same form factors as Arduino and Raspberry Pi boards, which can be used as replacements for the Arduino and Raspberry Pi’s and provide the capabilities to convert your hardware (projects or devices/sensors) into IoT capable smart devices.
This project demonstrates the versatility of the EzloPi platform as we interface an LED with the ESP32-based WEMOS D1 R32, which is used as a EzloPi smart device. The project aims to create a simple IoT device by interfacing an LED with the WEMOS D1 R32 and integrating it into the EzloPi ecosystem. This project will enable users to control the LED remotely through the MiOS applications, providing a foundation for more complex IoT applications.
- ESP32 WEMOS D1 R32 as an EzloPi smart device.
- LED (1.8V to 3.3V DC)
- Resistor of 120 ohm.
The wiring diagram of ESP32 WEMOS D1 R32 32 pin is represented as follows:
From ESP32 WEMOS D1 R32 (30 pins) to the LED:
- Connect the GND from the ESP32 WEMOS D1 R32 to the cathode (shorter leg) of the LED.
- Connect the I02 pin from the ESP32 to the pin of the resistor and the second pin of the resistor connects with the positive terminal (anode) and long leg of the LED.
3. Interfacing the LED to the ESP32 WEMOS D1 R32 with EzloPi Web Flasher
Click Connect.
- An Digital Output window will open for inputting the following parameters:
- Set a Device Name of your choosing. In our case, we set it to Ezlo Wemos LED.
- Set Device Subtype to LED.
- Set the IN GPIO to 2.
- Now Click the Apply button.
4. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. The LED can be controlled remotely with the MiOS app after it is successfully interfaced with the WEMOS D1 R32 as our EzloPi smart device.
5. MiOS Web Application
- After opening the MiOS web dashboard, you will be able to see the tile of your connected device. The LED can be controlled remotely with the MiOS app after it is successfully interfaced with the WEMOS D1 R32 as our EzloPi smart device.
