Smart projects to make life easier
LED-based traffic lights control system
This project uses an LED traffic light module interfaced with the EzloPi device to efficiently manage traffic signals. The designed system mimics real-world traffic light operations by controlling red, yellow, and green LEDs in a sequential manner, ensuring smooth traffic flow. This project can be expanded to include smart traffic management features such as sensor-based adaptive control, making it ideal for educational, prototyping, or small-scale automation purposes. The system demonstrates an easy-to-implement smart and cost-effective solution for traffic signal simulation.
- LED traffic light module.
From ESP32 to the Traffic Light Module:
| ESP32 | Traffic Light module |
| GND | GND |
| D15 | R(Red) |
| D4 | Y(Yellow) |
| D5 | G(Green) |
4. Interfacing the LED Traffic Lights with the EzloPi Web Flasher:
Click Connect
- Set a Device name of your choosing. In our case, we set it to the Red.
- Set Device Subtype to LED.
- Set the OUT GPIO to 15.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on Digital Output.
- Set a Device name of your choosing. In our case, we set it to the Yellow.
- Set the OUT GPIO to 4.
- Now Click the Apply button.
- Set a Device name of your choosing. In our case, we set it to the Green.
- Set the OUT GPIO to 5.
- Now press the Flash Device Button.
5. MiOS Web Dashboard
- On the MiOS web dashboard, you will be able to see the tiles of connected devices. In our case, we have three visible tiles for the LED traffic lights which are Red, Yellow and Green. These LED tiles will imitate the general traffic lights as demonstrated on the roads.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on EzloPi.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test011.
- Set Node Type to Date and Time.
- Set the Node to Interval.
- Set the Value to 15.
- Set the Value Type to Seconds.
- Set these values in the True part of the ACTION section.
- Set the Controllable to Red.
- Set the Capability to switch.
- Set the value to true.
- Set these values in the False part of the ACTION section.
- Set the Value Type to set.
- Set the value to false.
- Again Click on Create new Meshbot and under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test012.
- Set the Controllable to Yellow.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test013.
- Set the Value to 10.
- Set the Controllable to Green.
- Now Click the Save button.
- Here, you can see your saved MeshBot. Now click on Dashboard.
- Here as seen above in the three pictures on the MiOS web dashboard, we can see that as we have applied the time meshbot to the three LEDs just like traffic lights so the Red LED lights up for 15 seconds, Yellow LED light up after 10 seconds together with Red LED for 5 seconds and then they both turn OFF. Green LED turns ON for 10 seconds just as we set it in the meshbot.
6. MiOS App
- Here as seen above in the three pictures on the MiOS mobile application, we can see that as we have applied the time meshbot to the three LEDs just like traffic lights so the Red LED lights up for 15 seconds, Yellow LED light up after 10 seconds together with Red LED for 5 seconds and then they both turn OFF. Green LED turns ON for 10 seconds just as we set it in the meshbot.
