LDR digital module with LED
In this example, we will be interfacing an LDR (Light Dependent Resistor) module and LED light to the EzloPi device. By interfacing an LDR module and LED light with the EzloPi device, we can incorporate light sensing capabilities into various IoT projects.
Here, the LDR module works as a no-touch switch, when the light incident on the LDR module is blocked, the LED light will turn ‘OFF’. Similarly, when the light is blocked again, the LED light will turn ‘ON’. By repeating these actions, we can control the state of the LED light.
Welcome to the project demonstration video section. The following video showcases the key aspects of LDR digital module, providing a visual walkthrough of its implementation.
  • LM393 Photoresistor Resistance module.
  • LED with a current limiting resistor of 82 Ohms.
The wiring diagram for ESP32 30 pins is represented as follows:
LDR with LED Wiring Module
Breadcrumb
From ESP32 30 pins to LDR Module:
  • Connect 3V3 from the ESP32 to the VCC of the module.
  • Connect GND from the ESP32 to the GND pin on the module.
  • Connect D4 from the ESP32 to the D0 Pin on the LDR module.
From ESP32 30 pins to the LED:
  • Connect the D5 pin from the ESP32 to the LED anode (long leg) through a current limiting resistor of 82 Ohms.
  • Connect the GND to the cathode (short leg) of the LED.
4. Interfacing the LDR sensor module using EzloPi Web Flasher
MiOS Account Login
Device Status
  1. Now click on Connect Device and a pop-up window will appear
Connection to a Serial port
Click Connect.
EzloPi Ready to Flash
  2. In the Device Configuration, tab click on Digital Output.
  • Set a device name of your choosing. In our case, we set it to LDR with LED.
  • Set Device subtype to LED.
  • Set OUT GPIO to 5.
  • Set Resistor to PULL UP.
  • Set the default value to LOW.
  • Check the Button Enable box.
  • Set INP GPIO to 4.
  • Set Resistor to PULL DOWN.
  • Now Click the Apply button.
Configuration Selection
Flashing in Progress
LDR with LED Device Configuration
5. MiOS App
Google PlayApple App Store
MiOS App
MiOS
Select a Location
LED with LDR
  1. After opening the dashboard, you will be able to see the tile of your connected device. The LDR module works as a no-touch switch, the state of the LED is controlled by blocking the light incident to the LDR module.
  2. When the light incident on the LDR module is blocked, the LED light will turn ‘OFF’.
LED with LDR OFF
  1. Similarly, when the light is blocked again, the LED light will turn ‘ON’.
6. MiOS Web Application
Login to MiOS
Dynamic Dashboard
  1. After opening the web dashboard, you will be able to see the tile of your connected device. The LDR module works as a no-touch switch, the state of the LED is controlled by blocking the light incident to the LDR module.
LED with LDR ON
Buy Components
