JSN-SR04T Ultrasonic Sensor
This project provides a demonstration of how to interface a JSN-SR04T ultrasonic sensor with an EzloPi device, creating a versatile and cost-effective smart system for distance measurement and proximity detection.
The EzloPi device, powered by the ESP32 MCU, serves as the central control unit and provides connectivity and monitoring for the sensor. The JSN-SR04T ultrasonic sensor employs sound waves to measure distances, making it suitable for a wide range of applications including home automation, security systems, and industrial monitoring. By combining the sensor with the EzloPi platform, users can accurately measure distances and trigger actions based on proximity, and harness its capabilities to enhance their smart home or IoT projects.
The following components are required for interfacing the ultrasonic sensor module with the EzloPi device:
  • JSN-SR04T Waterproof Ultrasonic Sensor with analog to digital interface module.
JSN-SR04T Wiring
JSN-SR04T Circuit Setup
From ESP32 (30 pin) to the JSN-SR04T Module:
  • Connect the GND from the ESP32 to the GND pin of the module.
  • Connect the Vin pin from the ESP32 to the 5V pin.
  • Connect the D4 pin from the ESP32 to the Tx pin on the module.
  • Connect the D5 pin from the ESP32 to the Rx pin on the module.
3. Interfacing the Ultrasonic Sensor JSN-SR04T Module using EzloPi Web Flasher
Dimmable LED
  1. Log in using the credentials that you just set earlier while signing up.
Login
Connect Device
  1. Now, select the COM Port to which your ESP32 device is connected. In our case, the COM3 port is used.
Click Connect
Configuration
  1. If you are new to this and it’s your first time configuring, select Create new Device ID. Enter Wi-Fi SSID and Wi-Fi Password.
7. Another window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case, we set it to JSNSR04T.
  • Set Device Sub Type to JSN SR04T
  • Set the GPIO1 to 4.
  • Set the GPIO2 to 5
  • Now Click the Apply button. After clicking the apply button you can see a table of your settings in the device configuration tab.
8. A window will appear on the bottom right side of the screen displaying “Please press BOOT button while flashing begins.”
BOOT Button
9. Hold the BOOT button down until the next window appears on the bottom right side of the screen which says “Installation prepared. Please release the boot button now.”
JSN-SR04T Installation
JSN-SR04T Device Flashed
4. MiOS App
Google PlayApple App Store
MiOS Installed App
MiOS Login
Controllers Connected
JSN-SR04T Controller
  1. After opening the dashboard, you will be able to see the tile of your connected device.
  2. As you can see in the MiOS app dashboard, we can see the ultrasonic sensor tile which displays the distance in meters between the sensor and the object placed in front of it.
5. MiOS Web Application
Login To MiOS
JSN-SR04T Web Flasher
  1. Now, we can see the ultrasonic sensor tile displaying the distance measured by the sensor to the object that is placed in front of the sensor.
Buy Components
