Detect Motion with FC-51 and EzloPi!
In this project, we will interface a buzzer with the FC-51 IR proximity sensor using the EzloPi device and trigger a buzzer alarm when it detects motion within the sensor’s range.
The FC-51 IR sensor is a commonly used electronic component in various DIY electronics projects, automation and robotics. It operates by emitting infrared light and measuring the reflection of this light to detect the presence or absence of objects in its proximity. This sensor is widely used for various applications such as obstacle detection, motion sensing, and proximity detection.
Welcome to the project demonstration video section. The following video showcases the key aspects of IR Sensor with Buzzer, providing a visual walkthrough of its implementation.
The IR sensor connection wiring diagram of ESP32 30 pin is represented as follows:
From ESP32 to IR Proximity Sensor:
From ESP32 to the Buzzer Sensor:
Click Connect.
