Feel the Beat: EzloPi smart device Dances with Vibration Sensor Brilliance.
Interfacing vibration sensor with esp32
Here we will be interfacing an ESP32 Vibration Sensor with the EzloPi Smart Device. By integrating a high-performance vibration sensor with EzloPi, we bring you a solution that not only detects subtle movements but also empowers your smart environment with real-time responsiveness.
EzloPi’s meticulously crafted interface ensures that every vibration is translated into actionable data, providing a new dimension to home automation. Whether you seek enhanced security or wish to create interactive scenarios triggered by motion.
Explore the synergy of technology and intelligence as the EzloPi smart device effortlessly interprets vibrations, transforming your space into a dynamic, responsive environment. EzloPi smart device turns your place into a smart, dynamic hub where every move counts.
Welcome to the project demonstration video section. The following video showcases the key aspects of Create your own smart ESP32 vibration sensor using EzloPi Platform, providing a visual walkthrough of its implementation.
2. Vibration Sensor Circuit Diagram & Interface
The following components are required for interfacing using the EzloPi device:
- ESP32 as EzloPi smart device.
- LM393 vibration sensor Module.
From ESP32 to the Vibration Sensor Module:
- Connect the 3v3 pin from ESP32 to the VCC terminal on the vibration sensor Module.
- Connect GND to the GND Pin.
- Connect D5 from the ESP to the signal (D0) pin.
3. Interfacing the Vibration Sensor Module with EzloPi Web Flasher:
Click Connect.
- A window will open for inputting the following parameters:
- Set a device name of your choosing. In our case, we set it to MQ7.
- Set Device subtype to MQ7 CO Gas Sensor.
- Check the box of GPIO 1.
- Set OUT GPIO 1 to 33.
- Then Click Apply Button.
4. MiOS App
- After opening the dashboard, you will be able to see the tile of your connected device.
- Here, as you can see in the MiOS mobile app dashboard, the vibration sensor tile, which shows the NO Motion.
- Similarly, when it detects the vibration, “Motion” is appeared on the tile.
5. MiOS Web Application
- In the dashboard, you can also see the tile labeled as vibration sensor, which is showing No motion on the tile.
- Similarly, when it detects the vibration, “Motion” appears on the tile.
