Discover smart switching with EzloPi!’
Interfacing SPDT mini toggle switch 3-pin
This project aims to interface an SPDT mini toggle switch with the EzloPi device to demonstrate how we can implement the switch operation by controlling its state. The SPDT switch, which has three terminals (common, normally open, and normally closed), will be connected to the GPIO pins of the EzloPi device. The project includes reading the switch’s current state and displaying the status of the switch on the MiOS application dashboard tile. This simple setup can be enhanced and used for applications like switching between different modes or activating/deactivating specific sensors and features interfaced with the EzloPi device.
Welcome to the project demonstration video section. The following video showcases the key aspects of Interfacing SPDT mini toggle switch 3-pin, providing a visual walkthrough of its implementation.
- SPDT toggle switch.
From ESP32 to SPDT Switch:
ESP32 | SPDT Swtich |
VCC | COM |
D15 | L2 |
4. Interfacing the SPDT Toggle Switch using the EzloPi Web Flasher
Click Connect
- Set a Device name of your choosing. In our case, we set it to the SPDT Switch.
- Set Device Subtype to Switch / Button / Key.
- Set Resistor to PULL DOWN.
- Now, Click the Apply button.
5. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device.
- As you can see in the MiOS mobile dashboard, we can see the SPDT switch tile. When the SPDT switch is not operated/turned on, the tile will display the "off” message as shown in the above image.
- Similarly, when the SPDT gets operated/turned on, the switch will display the “On” message as depicted in the above image.
6. MiOS Web Dashboard
- As you can see in the MiOS web dashboard, we can see the SPDT switch tile. When the SPDT switch is not operated/turned on, the tile will display the "off” message as shown in the above image.
MeshBots:
