Interfacing and Speed Control of B366 Mini DC Motor
The primary goal of this project is to interface a B366 mini DC motor and implement a system for controlling its speed by using a MOSFET trigger switch module. The speed of the motor is controlled by integrating it with the EzloPi platform and through the MiOS app, which enables remote control and monitoring capabilities to its users. The project showcases the integration of modern IoT technology with traditional motor control systems, providing users with a reliable and user-friendly solution for interfacing and controlling the mini DC Motor.
Welcome to the project demonstration video section. The following video showcases the key aspects of Speed Control of Mini DC Motor on EzloPi platform, providing a visual walkthrough of its implementation.
  • B366 Mini DC Motor.
  • MOSFET Trigger Switch Driver Module (5 to 36V DC).
The following connections are made in order to complete the entire circuit setup:
From ESP32 (30 pins) to the MOSFET Trigger Switch Driver Module:
  • Connect the GND from the ESP32 to the terminal of the MOSFET trigger switch driver module.
  • Connect the D27 pin from the ESP32 to the pin TRIG/PWM of MOSFET trigger switch driver module.
From DC Motor to the MOSFET Trigger Switch Driver Module:
  • Connect the GND from the DC motor to the (OUT -) of the MOSFET trigger switch driver module.
  • Connect the positive “+” pin from the DC motor to the pin (OUT +) of the MOSFET trigger switch driver module.
4. Interfacing the DC Motor with EzloPi Web Flasher:
Click Connect.
  1. In the Device Configuration, tab click on PWM.
  1. A PWM window will open for inputting the following parameters:
  • Set a Device Name of your choosing. In our case, we set it to Motor Speed Control.
  • Set Device Subtype to Dimmable Lamp.
  • Set the PWM GPIO to 27.
  • Set the Resolution to 8-bit.
  • Now Click the Apply button.
5. MiOS App
Google PlayApple App Store
  1. After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device.
  1. We can control the state and speed of the DC motor remotely by using the slider bar present on the motor tile.
6. MiOS Web Application
  1. After opening the MiOS web dashboard, you will be able to see the tile of your connected device.
Buy Components
