Smart water quality monitoring!
Intelligent water quality and level monitoring system
This intelligent water quality and level monitoring system leverages the TS-300B turbidity sensor, two float switches, and an LED, all integrated with the EzloPi device. This system continuously monitors water turbidity to assess water quality, while the float switches detect high and low water levels to prevent overflow or dry conditions. The LED provides visual alerts for turbidity thresholds and water level statuses. With real-time data alerts and user-friendly controls, it offers an efficient solution for managing water systems in aquariums, water tanks, or reservoirs, ensuring optimal water quality and conservation.
- 2 Float switches for both high and low levels.
- LED with 100 Ohm resistor.
- Single-channel relay module.
- AC bulb and 220V AC plug
From ESP32 to Turbidity Sensor Interface Board:
| ESP32 | Interface Board |
| GND | 1 |
| D33 | 2 |
| 3V3 | 3 |
From Turbidity Sensor to Interface Board:
| Turbidity Sensor | Interface Board |
| IR | G |
| TR | A |
| VCC | V |
From ESP32 to both Float Switches:
| ESP32 | Float Switch 1 | Float Switch 2 |
| GND | Terminal 1 | Terminal 1 |
| D15 | Terminal 2 | - |
| D4 | - | Terminal 2 |
From ESP32 to LED & Resistor:
| ESP32 | LED | Resistor |
| GND | Cathode | - |
| D5 | - | Terminal 1 |
| - | Anode | Terminal 2 |
From ESP32 to Relay module:
| ESP32 | Relay |
| VCC | VCC |
| GND | GND |
| D5 | S |
| ESP32 | Bulb | 220AC |
| COM | NA | Neutral |
| NO | 1st Terminal | NA |
| NA | 2nd Terminal | Phase |
4. Interfacing the Turbidity sensor with EzloPi Web Flasher
Click Connect
- Set a Device name of your choosing. In our case, we set it to Turbidity.
- Set Device Subtype to Turbidity Sensor.
- Set the ADC input pin to 33.
- Set the Resolution to 10-bit.
- Then Click Apply Button.
- A Digital Input window will be opened for inputting the following parameters:
Set a Device name of your choosing. In our case, we set it to Float Switch High.
Set the Input GPIO pin to 15.
Set Device Subtype to Float Switch.
Set the Resistor to PULL DOWN
- In the Device Configuration, tab click on Digital Input
- Set a Device name of your choosing. In our case, we set it to Float Switch High.
- Set the Input GPIO pin to 15.
- Set Device Subtype to Float Switch.
- Set the Resistor to PULL DOWN
- Set a Device name of your choosing. In our case, we set it to LED.
- Set Device Subtype to LED.
- Set the OUT GPIO to 5.
- Set a Device name of your choosing. In our case, we set it to Relay.
- Set Device Subtype to Relay.
- Set the OUT GPIO to 13.
5. MiOS Web Dashboard
- Here, on the MiOS web dashboard, you will be able to see the tiles of connected devices. In our case, we have five visible tiles for the different devices. Two float switches are used for high low water level monitoring whereas the turbidity sensor is used to monitor the water quality or cleanliness of water. The relay is used for refilling the water storage tank while the LED is used for water filter indication if it is ok or needs to be replaced.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on Ezlopi.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test011.
- Set Node Type to Device.
- Set the Node to Float Switch Low.
- Set the Armed State to any.
- Set the Value to water_level_above_high_threshold.
- Add another Device by pressing the Add Trigger button.
- Set the Value to water_level_above_low_threshold.
- Set Controllable to Relay.
- Set the Capability to switch.
- Set the value to true.
- Set Controllable Type to Relay.
- Set the value to false.
- Here, you can see your saved MeshBot. Now again click on Create new Meshbot.
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on EzloPi.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test012.
- Set the Node to Float Switch High.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test013.
- Set the Node to Turbidity.
- Set the Capability to Water filter replacement alarm.
- Set the Value to repace_water_filter.
- Set Controllable to LED.
- Here, you can see your saved MeshBot. Now click on Dashboard.
- On the MiOS web dashboard, we can see the Float switch Low is showing message
‘water_level_above_high_threshold, which means that water level is below our low limit so we need to turn on the pump to refill the water in the tank that's why it is depicted that Relay is turned ON to show running of motor or pump, this logic is set in meshbot.
- Now, In this scenario, we can see the Float switch High is showing message ‘water_level_above_high_threshold, Which means that water level is going above our high limit so we need to turn off the running motor or pump to make sure that tank does not overflow so it is shows here that Relay is turned OFF to show turning off of motor or pump, this condition is set in meshbot.
- When the water is not clear or impurities have increased, the tile will display the ”replace water filter” message. So, in the above pic the turbidity tile is showing "replace water filter” message therefore LED turns ON because of the meshbot conditions.
6. MiOS App
- On the MiOS mobile dashboard, we can see the Float switch Low is showing message
