Smart lighting control with EzloPi!
Intelligent street light management using LDR technology
The following project utilizes the LDR module to monitor ambient light levels and automatically control a miniature street light connected to the EzloPi device. The system ensures energy efficiency by turning the lights on during low-light conditions and off during daylight. The LDR provides real-time feedback to the EzloPi device, enabling precise control and adaptability to varying lighting environments. This setup is ideal for smart city applications, reducing energy consumption and enhancing sustainability. Its compact design and easy integration make it a practical solution for modern lighting systems.
- LM393 Photoresistor Module(LDR).
- Miniature illuminated street light.
From ESP32 to the LDR module:
| ESP32 | LDR |
| VIN | +5V |
| GND | GND |
| D13 | D0 |
From ESP32 to the Mini Street Light:
| ESP32 | Mini Street Light |
| GND | GND |
| D15 | V+ |
4. Interfacing the LDR with Street Light using the EzloPi Web Flasher
Click Connect
- A Digital Input window opens for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to LDR.
- Set INPUT GPIO to 13.
- Set Device subtype to LDR Digital Sensor.
- Set the Resistor to PULL DOWN.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on Digital Output.
- A Digital Output window opens for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to Street Light.
- Set INPUT GPIO to 15.
- Set Device subtype to LED.
5. MiOS Web Dashboard
- On the MiOS web dashboard, you will be able to see the tiles for the LDR digital sensor and mini street light. The street light will be triggered depending upon the functioning of the LDR.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on Local.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test0017.
- Set Node Type to Device.
- Set the Node to LDR.
- Set the Capability to Switch.
- Set the armed state to any.
- Set the Value to True
- Set these values in the ACTION section:
- Click on the TRUE part of the Add Action section..
- Set Controllable Type to Street Light.
- Set the Capability Type to switch.
- Set the Value to false.
- Set Action to immediately.
- Click on the False part of the Add Action section..
- Set the Value to true.
- Set Action immediately.
- Now Click the Save button.
- Now, on the MiOS web dashboard, you can see that when the LDR receives a decent amount of sunlight therefore the street light remains OFF because it's showing that there is a proper light on the streets. This condition is set in the meshbot.
- Here, in the above picture, we can see that when LDR is triggered OFF due to low light or no light then our street light turns ON due to the condition we have set in the meshbot.
6. MiOS App
- On the MiOS mobile dashboard, you can see that when the LDR receives a decent amount of sunlight therefore the street light remains OFF because it's showing that there is a proper light on the streets. This condition is set in the meshbot.
