Intelligent lighting solution for seating areas
The intelligent lighting solution for seating areas utilizes the TSL2561 luminosity sensor and a force sensitive resistor (FSR) to create a smart and energy-efficient lighting system. The TSL2561 sensor measures ambient light levels to adjust the brightness of the LED strip dynamically, ensuring optimal illumination. The FSR detects the presence or absence of a person in the seating area, triggering the lighting system accordingly. The entire setup is seamlessly interfaced with the EzloPi device, enabling precise control and automation. This solution enhances user comfort while minimizing energy consumption, making it ideal for modern seating arrangements.
  • TSL2561 luminosity sensor.
  • Force sensitive resistor with pull-down resistor.
  • LED strip.
  • XY-MOS, high-power dual MOSFET driver module.
From ESP32 to the TSL2561:
ESP32TSL2561
3V3Vin
GNDGND
D21SDA
D22SCL
From ESP32 to the Force Sensitive Resistor with Pull-down resistor:
ESP32Force Sensitive ResistorPull Down Resistor
3V3Terminal 1-
D33Terminal 2Terminal 1
GND-Terminal 2
From ESP32 to the MOSFET driver module:
ESP32MOSFET driver module
D23Trig
GNDGND
From MOSFET driver module to LED Strip:
MOSFET DriverLED Strip
OUT+5V
OUT-GND
4. Interfacing the Luminosity Sensor, FSR & Booklight LED using the EzloPi Web Flasher:
Click Connect
  2. In the Device Configuration, tab click on I2C.
  1. An I2C window will be opened for inputting the following parameters:
  • Set a Device name of your choosing. In our case, we set it to Luminosity Sensor.
  • Set Device subtype to TSL2561 Luminosity Sensor.
  • Set the Slave address to 57.
  • Set the SDA to 21.
  • Set the SCL to 22.
  • Tick mark both the boxes of Enable pullup.
  • Then Click Apply Button.
  1. Again, In the Device Configuration, tab click on Analog Input
  1. An Analog Input window will be opened for inputting the following parameters:
  • Set a Device name of your choosing. In our case, we set it to Force Sensitive Resistor.
  • Set Device Subtype to Force Sensitive Resistor.
  • Set the ADC input pin to 33.
  • Set the Resolution to 10-bit.
  1. Again, In the Device Configuration, tab click on Analog Input.
  1. Again, In the Device Configuration, tab click on Digital Output.
  1. A Digital Output window will be opened for inputting the following parameters:
  • Set a Device name of your choosing. In our case, we set it to the Booklight LED.
  • Set Device Subtype to LED.
  • Set the OUT GPIO to 23.
  • Set the Resistor to PULL UP.
  • Now Click the Apply button.
5. MiOS Web Dashboard
  1. Here, on the MiOS web dashboard, you will be able to see the tiles of the connected devices. In our case, we have TSL2561 luminosity sensor, Force Sensitive Resistor and Booklight LED tiles. The Booklight LED tile will indicate the status of the TSL2561 and Force sensitive sensor and whether or not the both sensor’s values are within the set threshold.
MeshBots:
  1. On the left side of the screen under Automation, click on MeshBots.
  2. On meshbot screen, click on Create new MeshBot button present on the top right corner of the screen.
  3. After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on Local.
  1. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test014.
  1. Set these things in TRIGGER section:
  • Set Node Type to Device.
  • Set the Node to TSL2561..
  • Set the Capability to parent_abstract.
  • Set the variables to uuid.
  • Set the Comparator to Less (<).
  • Set the Value Type to value.
  • Set the value to 10.
  • Add another trigger by pressing the Add Trigger button
  • Set the Node to Force Sensitive Resistor.
  • Set the Comparator to Greater (>).
  • Set the value to 90.
  1. Set these values in True part of the ACTION section.
  • Set Controllable Type to Device.
  • Set the Controllable to Booklight LED.
  • Set the Capability to power_command.
  • Set the Value Type to set.
  • Set the Value to true.
  • Now Click the Save button.
  1. Here you can see your saved MeshBot. Now click on Dashboard.
  1. Now in the MiOS web dashboard, we can see that when the Force sensitive resistor value is low, indicates that nobody is sitting on the seat whereas TSL2561 value is high indicating that there is enough light in the area that’s why our LED is OFF according to the condition set in the meshbot.
  1. Here in the above picture, it shows that when the Force sensitive resistor gets high indicating someone is sitting on the chair and also the TSL2561 Luminosity sensor gives a low value indicating there is low light in the area, then the LED turns ON because of our meshbot settings.
6. MiOS App
Google PlayApple App Store
  1. On the MiOS mobile dashboard, we can see that when the Force sensitive resistor value is low, indicates that nobody is sitting on the seat whereas TSL2561 value is high indicating that there is enough light in the area that’s why our LED is OFF according to the condition set in the meshbot.
Buy Components
