Implementation of KY-008 Laser module
Harness the power of EzloPi!
This project aims to interface the KY-008 laser transmitter module with the EzloPi device to create a precise laser signaling system. The KY-008 module is known for its low power consumption and high-intensity laser beam. The EzloPi device manages the control signals to modulate the laser's on/off states. This setup can be used for applications such as laser communication, object detection, or simple laser pointer tasks. The project involves programming the EzloPi device, configuring the GPIO pins, and ensuring safe and effective operation of the laser module.
Welcome to the project demonstration video section. The following video showcases the key aspects of Implementation of KY-008 Laser module, providing a visual walkthrough of its implementation.
  • KY-008 Laser sensor module (5V).
From ESP32 to KY-008:
ESP32 KY-008
VIN VCC (5V)
GND GND
D4 S (Signal)
4. Interfacing the Laser Sensor Module using the EzloPi Web Flasher
Click Connect
  2. In the Device Configuration, tab click on Digital Output.
  1. The Digital Output window will be opened for inputting the following parameters:
  • Set a Device name of your choosing. In our case, we set it to the Laser Module.
  • Set Device Subtype to LED.
  • Set the OUT GPIO to 4.
  • Set the Resistor to PULL UP.
  • Set the Default value to HIGH.
  • Now, Click the Apply button.
5. MiOS App
Google PlayApple App Store
  2. After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device.
  1. As you can see in the MiOS mobile dashboard, we can see the saser sensor tile. For now it is not triggered, so the tile is showing the “off” message.
  1. Similarly, when the KY-008 gets triggered, the tile will display the “On” message as depicted in the above image.
6. MiOS Web Dashboard
  1. As seen in the MiOS web dashboard above, we can see the laser sensor tile. For now it is not triggered, that is why the tile is showing the “off” message.
MeshBots:
Buy Components
