GY-61 3-Axis Accelerometer
Before moving into this example, it is very important to know about the device registration, provisioning and converting the ESP32 accelerometer device into an EzloPi device along with knowledge of Web Flasher, MiOS Mobile Application for Android/iOS and the MiOS Web Application.
1. About this example – GY-61 Sensor
This project aims to seamlessly integrate the GY-61 3-axis accelerometer module with the ESP32-based EzloPi smart device, unlocking a realm of dynamic possibilities for smart environment interaction. By connecting the GY-61 accelerometer to the EzloPi device, users can harness real-time acceleration data to enrich home automation, IoT applications, and personalized experiences.
GY-61 accelerometer when combined with the versatile EzloPi platform, can be used to design creative automation scenarios where specific movements trigger predefined actions, enhancing the smart home experience.
The following components are required for interfacing the touch sensor using the EzloPi device:
  • ESP32 as EzloPi smart device.
  • TT223B Capacitive Touch Sensor Module
GY-61 3-Axis Accelerometer Diagram
GY-61 3-Axis Breadboard
The following connections are made to complete the circuit setup.
From ESP32 (30 pins) to the GY-61 module:
  • Connect the GND from the ESP32 to the GND pin of the GY-61 module.
  • Connect the D32 pin from the ESP32 to the GY-61 pin labeled with X_OUT.
  • Connect the D33 pin from the ESP32 to the GY-61 pin labeled with Y_OUT.
  • Connect the D25 pin from the ESP32 to the GY-61 pin labeled with Z_OUT.
  • Connect the Vin pin from the ESP32 to the GY-61 Vcc pin.
The wiring diagram of ESP32 38 pin is also represented as below:
Wiring Diagram
From ESP32 (38 pins) to the GY-61 module:
  • Connect the IO32 pin from the ESP32 to the GY-61 pin labeled with X_OUT.
  • Connect the IO33 pin from the ESP32 to the GY-61 pin labeled with Y_OUT.
  • Connect the IO25 pin from the ESP32 to the GY-61 pin labeled with Z_OUT.
3. Interfacing the GY-61 Accelerometer module using EzloPi Web Flasher
Login
  1. Log in using the credentials that you just set earlier while signing up.
Device Status
  1. Now click on Connect Device and a pop-up window will appear
PCI Serial Port
  1. Now, select the COM Port to which your ESP32 accelerometer device is connected. In our case, the COM3 port is used.
Click Connect.
Device Status
  2. In the Device Configuration, tab click on Analog Input.
  • Set a device name of your choosing. In our case, we set it to GY-61.
  • Set Device Subtype to GY61.
  • Check the checkbox of GPIO 1, GPIO 2, and GPIO 3.
  • Set the GPIO 1 to 32, GPIO 2 to 33, and GPIO 3 to 25.
  • Now Click the Apply button.
  • After clicking the apply button you can see a table of your settings in the device configuration tab configuration tab.
Ready to Flash
  1. A window will appear on the bottom left side of the screen displaying “Please press BOOT button while flashing begins.”
  2. Hold the BOOT button down until the next window appears on the bottom left side of the screen which says “Installation prepared. Please release the boot button now.”
  1. Release the BOOT button from your ESP32 accelerometer when this pop-up on the bottom right window appears.
Flashing in Progress
4. MiOS App
Google PlayApple App Store
MiOS App
MiOS
Select a Location
Dashboard
  1. Now, you will see three tiles on the MiOS mobile dashboard, each of them representing the acceleration values along the X, Y, and Z axis.
  2. Accelerometers are useful for sensing vibrations in systems or for orientation applications. So, when the GY-61 module changes its orientation on any axis, the above values will also vary.
5. MiOS Web Application
Login to MiOS
Dynamic Dashboard
  1.  As we can see on the MiOS web dashboard, the three tiles each represent the acceleration values along the X, Y, and Z axis as displayed above. When the GY-61 module changes its orientation on any axis, the above values will vary.
Buy Components
