Smart sensing with EzloPi!
Getting started with ESP32-C3 and Force Sensitive Resistor (FSR402)
The project aims to interface a force sensitive resistor (FSR402) with the ESP32-C3 based EzloPi device to measure and respond to varying pressure levels.
The ESP32-C3 offers several benefits over the ESP32, including enhanced power efficiency, improved RF performance with Bluetooth 5.0 and Wi-Fi 802.11ax (Wi-Fi 6) support, and increased security features like hardware encryption, making it ideal for IoT applications requiring robust wireless communication and low power consumption.
Welcome to the project demonstration video section. The following video showcases the key aspects of Getting started with ESP32-C3 and Force Sensitive Resistor (FSR402), providing a visual walkthrough of its implementation.
- ESP32-C3 as an EzloPi smart device.
- Force sensitive resistor FSR402.
- Resistor 10K ohm.
From ESP32C3 to the FSR402 & Resistor:
| ESP32 | FSR402 | Resistor |
| 3V3 | 1st terminal of the sensor | |
| GND | 1st terminal of the resistor | |
| GPIO0 | 1st terminal of the sensor | 2nd terminal of the resistor |
4. Interfacing the Force Sensitive Resistor by using the EzloPi Web Flasher
Click Connect
- If you are new to this and it's your first time configuring, select Create new Device ID. Click on the Configure Wifi button. Enter Wifi SSID and Wifi Password.
- In the Device Configuration, Select Chip Type ESP32S3(8MB).
- Set a Device name of your choosing. In our case we set it to FSR402.
- Set the Device SubType to Force Sensitive Resistor (FSR).
- Set the ADC input pin to 0.
- Set Resolution to 12-bit.
- Now, Click the Apply button.
5. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. We can see the pressure/force being exerted to the resistor by using the MiOS smart platform.
6. MiOS Web Dashboard
- After configuring the controller with the EzloPi web flasher, head to https://ezlogic.mios.com/
- After opening the MiOS web dashboard, you will be able to see the tile of your connected device. We can see the pressure/force being exerted to the resistor by using the MiOS smart platform.
