Get notified when fan gets powered ON
In this EzloPi project, we will be creating a smart fan control system using the EzloPi device. The goal is to provide a convenient touch-based fan control while utilizing the limitless capabilities and smartness of the EzloPi platform. The fan state can also be controlled by using the MiOS smart platform applications by simply tapping on the fan tile which is demonstrated in our setup and interfacing guide.
By utilizing the EzloPi device, we can integrate this smart fan control system into our home automation setup or as part of a larger project. We can also enhance the project further by adding additional sensors like temperature or humidity sensors or IR sensors to enable automated fan control based on ambient room conditions and detected motion.
Welcome to the project demonstration video section. The following video showcases the key aspects of Get notified when fan gets powered ON, providing a visual walkthrough of its implementation.
- TTP223B Touch Sensor.
- XL6009 DC to DC Boost Converter Module.
- 5V Relay module
- 12V DC fan.
From ESP32 to TTP223B Touch Sensor:
| ESP32 | TTP223B |
| 3V3 | VCC |
| GND | GND |
| D4 | I/O |
From ESP32 to Relay Module & DC-DC Boost Converter:
| ESP32 | Relay Module | DC-DC Booster Converter |
| Vin | +ve & COM | |
| GND | -ve | IN- |
| D5 | S | |
| NO | IN+ |
From DC-DC Boost Converter to Fan:
| DC-DC Booster Converter | Fan |
| OUT+ | Terminal 1 |
| OUT- | Terminal 2 |
4. Interfacing the Fan Control using Touch Sensor with the EzloPi Web Flasher
Click Connect
- Set a device name of your choosing. In our case, we set it to Fan with Touch.
- Set Device Subtype to Relay,
- Set the OUT GPIO to 4.
- Set the Resistor to PULL UP
- Tick mark the Button Enable Box.
- Set the IN GPIO to 5.
- Set the Resistor to PULL DOWN.
- Then Click Apply Button.
5. MiOS Web Dashboard
- On the MiOS web dashboard, the tile is displayed for our fan control using the touch sensor project. When we press or touch on the touch sensor module, the fan will turn ON. Also the tile will be updated and will be shown as ON.
- Similarly as shown above, when we again touch on the touch sensor module, the fan will turn OFF. Also the tile will be updated and will be shown as OFF as in the above figure.
MeshBots:
- After clicking on Create new MeshBot you will see new options, now under Notification MeshBot click on Create.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test005.
- Set Node Type to Device.
- Set the Node to Fan with Touch.
- Set the Capability to Switch.
- Set the value to True
- Set Controllable Type to Notification.
- Set the User to Your user account.
- Set the Channels to email, push.
- Set the Subject to Fan Update.
- Write the suitable Message body that you want to receive in your email. As you can see, we write, Fan turns ON.
- As seen in the MiOS web dashboard above, the fan is ON, which means that the touch sensor has been operated or given a touch input.
- As soon as the fan gets powered ON, we can see that we receive an automated email through the Meshbot feature.
6. MiOS App
- After opening the dashboard, you will be able to see the tile of your connected device.
- On the MiOS mobile dashboard, the tile is displayed for our fan control using the touch sensor project. When we press or touch on the touch sensor module, the fan will turn ON. Also the tile will be updated and will be shown as ON and the user will be notified through an automated email.
