Discover smart innovation with EzloPi!
Flow monitoring and voltage monitoring with shunt voltmeter
The following project integrates the YF-S201 flow sensor and a voltage sensor module with the EzloPi device for real-time monitoring applications. The YF-S201 flow sensor accurately measures liquid flow rates, providing data through its pulse output. Simultaneously, the voltage sensor module acts as a shunt voltmeter to monitor battery voltage, enabling efficient power management. The system ensures reliable voltage detection and flow monitoring, which can be visualized via the MiOS dashboard. This setup is ideal for battery-powered flow management systems, water usage tracking, and energy-efficient automation applications, offering precision, simplicity, and integration flexibility.
- Voltage sensor module.
- YF-S201 flow sensor.
- 3.7V battery
From ESP32 to the Voltage sensor:
ESP32 | Voltage sensor |
VIN | +(VCC) |
GND | -(GND) |
D33 | S(Signal) |
From Voltage sensor to Battery:
Voltage sensor | Battery |
VCC | +(VCC) |
GND | -(GND) |
From ESP32 to the YF-S201:
ESP32 | YF-S201 |
VIN | VIN |
GND | GND |
D32 | S(Signal) |
4. Interfacing the Voltage Sensor and Flow sensor using the EzloPi Web Flasher
Click Connect
- f you are new to this and it's your first time configuring, select Create new Device ID. Click on the Configure Wifi button. Enter Wifi SSID and Wifi Password.
- An Analog Input window will be opened for inputting the following parameters:
- Set the Device name of your choosing. In our case, we set it to the Voltage Sensor.
- Set the Device Subtype to Shunt Voltmeter.
- Set the ADC Input pin GPIO to 14.
- Set the Resolution to 10-bit.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on PWM
- A PWM window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to the Flow Sensor.
- Set the Device Subtype to YFS201 flowmeter.
- Set the PWM_GPIO to 32.
- Set the Frequency (KHz) from the Slider.
- Set the Resolution to 8 bits
5. MiOS App
- After opening the MIOS mobile app, you will be able to see the tiles of your connected devices. The voltage sensor shows the battery voltage connected to the circuit whereas the flow sensor shows the flow of the water which we want to monitor.
- Now, in the above picture, we can see that the voltage sensor shows battery voltage while the flow sensor shows the water flow rate. By this feedback, we can manage the flow of water.
6. MiOS Web Dashboard
- After opening the MIOS web dashboard, you will be able to see the tiles of your connected devices. The voltage sensor shows the battery voltage connected to the circuit whereas the flow sensor shows the flow of the water which we want to monitor.
