Flood prevention and water leak detection system
Smart prevention with EzloPi
The flood prevention and water leak detection system combines the FC-37 rain sensor module, photoresistor sensor module, and MH-FMD buzzer, interfaced with the EzloPi device for efficient monitoring and alerting. The rain sensor detects water accumulation or leakage, triggering a warning when predefined thresholds are crossed. The photoresistor sensor adds an additional layer by monitoring light intensity changes, which could signify environmental alterations during floods. The MH-FMD buzzer offers immediate audible alerts for timely intervention. This compact and smart system is ideal for homes and industrial spaces, ensuring proactive flood and leakage management.
  • FC-37 rain sensor module with LM393 comparator module.
  • LM393-based photoresistor sensor module.
  • MH-FMD buzzer
From ESP32 to the LM393 comparator module:
ESP32 LM393 Comparator Module
3V3 VCC
GND GND
D33 A0
From the LM393 module to the Rain sensor:
LM393 Comparator Module Rain Sensor Module
+ve pin POS
-ve pin NEG
From ESP32 to LDR Module:
ESP32 LDR module
VIN +5V
GND GND
D13 D0
From ESP32 to Buzzer:
ESP32 Buzzer
3V3 VCC
GND GND
D15 I/O
4. Interfacing the Rain sensor & LDR with Buzzer using the EzloPi Web Flasher:
Click Connect
  2. In the Device Configuration, tab click on Analog Input.
  1. An Analog Input window will be opened for inputting the following parameters:
  • Set a Device name of your choosing. In our case, we set it to Water Leak Sensor.
  • Set Device subtype to Water Leak Sensor.
  • Set the ADC input pin to 33.
  • Set the Resolution to 10-bit.
  • Then Click Apply Button.
  1. Again, In the Device Configuration, tab click on Digital Input
  1. A Digital Input window will be opened for inputting the following parameters:
  • Set a Device Name of your choosing. In our case, we set it to LDR.
  • Set the INPUT GPIO to 13.
  • Set Device Subtype to LDR Digital Sensor.
  • Set the Resistor to PULL DOWN.
  1. Again, In the Device Configuration, tab click on Digital Output.
  1. A Digital Output window will be opened for inputting the following parameters:
  • Set a Device name of your choosing. In our case, we set it to the Buzzer Alarm.
  • Set Device Subtype to LED.
  • Set the OUT GPIO to 15.
  • Set the Resistor to PULL UP.
5. MiOS Web Dashboard
  1. Here, on the MiOS web dashboard, you will be able to see the tiles of connected devices. In our case, we have a water leak sensor, LDR and buzzer tiles. The buzzer tile will alert the user about the flood situation whereas water leak sensor and LDR help in flood prevention.
MeshBots:
  1. On the left side of the screen under Automation, click on MeshBots.
  2. On meshbot screen, click on Create new MeshBot button present on the top right corner of the screen.
  3. After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on EzloPi.
  1. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test015.
  1. Set these things in TRIGGER section:
  • Set Node Type to Device.
  • Set the Node to Water Leak Sensor.
  • Set the Capability to Water leak alarm.
  • Set the Armed State to any.
  • Set the value to Water_leak_detected.
  • Add another trigger by pressing the Add Trigger button.
  • Set the Node to LDR.
  • Set the Capability to Switch.
  • Set the value to False.
  • Make sure to select AND Operation between the two triggers from top left corner in the trigger section.
  1. Set these values in the True part of the ACTION section.
  • Set Controllable Type to Device.
  • Set the Controllable to LED.
  • Set the Capability to power_command.
  • Set the Value Type to set.
  • Set the Value to true.
  1. Set these values in the False part of the ACTION section.
  • Set the Value to false.
  • Now Click the Save button.
  1. Here you can see your saved MeshBot. Now click on Dashboard.
  1. Now in the MiOS web dashboard, we can see that when there is no water or flood in the basement and light is being properly received by the LDR while the water leak sensor does not detect any water. Also the buzzer also remains OFF, this rule is set in the meshbot.
  1. Here in the above picture, it shows that when there is a flood situation then the water leak sensor detects water and buzzer alarm  is turned ON whereas LDR gets OFF because of blockage of light due to rainy conditions, these rules are set in the meshbot.
6. MiOS App
Google PlayApple App Store
  1. In the MiOS mobile app, we can see that when there is no water or flood in the basement and light is being properly received by the LDR while the water leak sensor does not detect any water. Also the buzzer also remains OFF, this rule is set in the meshbot.
Buy Components
