Unlock a world of seamless interaction with the power of touch
In this example, the use of the TTP223B touch sensor is demonstrated. By integrating the touch sensor with the EzloPi device, you can create interactive touch interfaces to trigger specific actions or control various smart devices. This combination offers a convenient and engaging way to enhance the functionality and user experience of your smart home or office setup.
Welcome to the project demonstration video section. The following video showcases the key aspects of Touch Switch, providing a visual walkthrough of its implementation.
The following components are required for interfacing the touch sensor using the EzloPi device:
From ESP32 to the Touch Sensor:
Now, select the COM Port to which your ESP32 device is connected. In our case, the COM3 port is used.
Click Connect.
