Soil Moisture Sensor
This example aims to demonstrate how we can interface the Soil Moisture Sensor with the EzloPi device to transform the sensor into a smart device.
By interfacing the sensor to the EzloPi device, we can remotely monitor the moisture levels of the soil through the MiOS user-friendly interface. This integration can allow for automated watering systems, providing an efficient and convenient way to maintain optimal soil conditions for plants.
The following components are required for interfacing using the EzloPi device:
  • ESP32 as EzloPi smart device.
  • FC-28 Soil Moisture Sensor Module.
From ESP32 to the Soil Moisture Sensor Module:
  • Connect the 3v3 pin from ESP32 to the VCC terminal on the moisture sensor module.
  • Connect GND to the GND Pin.
  • Connect D33 from the ESP to the signal (A0) pin.
From the Sensor Module to the FC-28:
  • Connect the (+) from Soil Moisture Sensor Module to one side of FC-28
  • Connect the (-) from Soil Moisture Sensor Module to the other side of FC-28
3. Interfacing the Touch Sensor using EzloPi Web Flasher
  1. Now click on Connect Device and a pop-up window will appear
Click Connect.
  2. In the Device Configuration, tab click on Analog Input.
  1. An Analog Input window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case we set it to Soil Moisture Sensor.
  • Set device Sub Type to Soil Moisture Sensor
  • Set ADC input pin to 33.
  • Set the Resolution to 10-bit
  • Now Click the Apply button. After clicking the apply button you can see a table of your setting in the device configuration tab.
  1. A window will appear on the bottom left side of the screen displaying “Please press BOOT button while flashing begins.”
  2. Hold the BOOT button down until the next window appears on the bottom left side of the screen which says “Installation prepared. Please release the boot button now.”
4. MiOS App
Google PlayApple App Store
MiOS Installed App
MiOS Login
Select a Location
  1. After opening the dashboard, you will be able to see the tile of your connected device.
  2. Here, as you can see in the MiOS mobile app dashboard, the soil moisture sensor tile, which shows the moisture level as 63% of the soil sample on which the sensor was used.
5. MiOS Web Application
Login MiOS
  1. In the web dashboard, you can see the tile labeled as soil moisture sensor. At this instance, the sensor is showing a moisture level of 41% of the soil.
Buy Components
