Be on the guard for leaks with EzloPi!
EzloPi MQ7 CO Gas Sensor
1. About this example - MQ7 ESP32
The following example illustrates the integration of the MQ7 CO Gas Sensor with the EzloPi device, showcasing its practical implementation. The MQ7 CO Gas Sensor is employed to monitor the concentration of carbon monoxide gas in the surrounding air, making it a valuable component for electronic projects and home automation systems. This integration allows users to establish threshold values for gas concentration levels, enabling the triggering of alerts or actions on the EzloPi device.
By incorporating the MQ7 CO Gas Sensor into the EzloPi device, a sophisticated gas detection and safety system can be created. This system proves invaluable in safeguarding against potential hazards posed by gas leaks in diverse environments, including residential spaces, offices, and industrial facilities.
Welcome to the project demonstration video section. The following video showcases the key aspects of creating your own smart CO sensor using MQ7 CO Gas Sensor on EzloPi Platform, providing a visual walkthrough of its implementation.
- MQ7 CO Gas Sensor.
MQ7 Sensor Pin Diagram - The wiring diagram for the ESP32 30 pin is represented as below:
The following connections are made in order to complete the entire MQ7 ESP32 circuit setup:
From ESP32 to SEN18 Water leak sensor:
- Connect 3V3 from the ESP32 to the VCC of the sensor.
- Connect the GND from the ESP32 to the GND pin of the sensor.
- Connect D2 from the ESP32 to the pin “S” of the sensor as an input.
From ESP32 to the Buzzer:
- Connect the D4 pin from the ESP32 to the Signal pin of the buzzer.
- Connect the GND to the negative pin of the buzzer.
4. Interfacing the MQ7 CO Gas sensor module with EzloPi Web Flasher:
- Log in using the credentials that you just set earlier while signing up.
Now, select the COM Port to which your ESP32 device is connected. In our case, the COM3 port is used.
Click Connect.
- A window will open for inputting the following parameters:
- Set a device name of your choosing. In our case, we set it to MQ7.
- Set Device subtype to MQ7 CO Gas Sensor.
- Check the box of GPIO 1.
- Set OUT GPIO 1 to 33.
- Then Click the Apply Button.
- After clicking the apply button you can see a table of your settings in the device configuration tab.
5. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. The MQ7 CO Gas Sensor tile reflects the concentration readings of the CO gas being detected by the sensor at that moment.
6. MiOS Web Application
- After opening the MiOS web dashboard, you see the tile of your connected device. The MQ7 CO Gas Sensor tile will reflect the concentration readings of the CO gas.
