The following example demonstrates how the MQ6 LPG Gas Sensor is interfaced with the EzloPi device and how it is implemented.
The MQ6 LPG Gas Sensor is a popular gas detection module widely used in electronic projects and home automation systems. It is capable of detecting various gasses, including LPG (liquefied petroleum gas) and butane. We can set the threshold values for gas concentration levels that trigger alerts or actions on the EzloPi device.
By interfacing the MQ6 LPG Gas Sensor with the EzloPi device, you can create a smart gas detection and safety system that helps protect against the dangers of gas leaks in various environments, from homes and offices to industrial facilities.
- MQ6 LPG Gas Sensor.
From ESP32 to the MQ6 LPG Sensor:
- Connect Vin from the ESP32 to the VCC of the sensor.
- Connect GND from the ESP32 to the GND pin of the sensor.
- Connect D33 from the ESP32 to the A0 Pin of the sensor.
3. Interfacing the MQ6 Gas sensor module with EzloPi Web Flasher:
Click Connect.
- A window will open for inputting the following parameters:
- Set a device name of your choosing. In our case, we set it to MQ6.
- Set Device subtype to MQ6 LPG Gas Sensor.
- Check the box of GPIO 1.
- Set OUT GPIO 1 to 33.
- Then Click Apply Button.
4. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. The MQ6 LPG Gas Sensor tile reflects the concentration readings of the LPG gas being detected by the sensor at that moment.
5. MiOS Web Application
- After opening the MiOS web dashboard, you see the tile of your connected device. The MQ6 LPG Gas Sensor tile will reflect the concentration readings of the LPG gas. As shown above, there is no gas being currently detected by the sensor.
