EzloPi LED ON/OFF
LED ON/OFF
Shine a Light on Innovation with EzloPi
Top Projects
LED ON/OFF
This example demonstrates a simple circuit setup by using the EzloPi device, which provides a convenient platform for building IoT applications. With its built-in Wi-Fi and GPIO capabilities, it provides an ideal foundation for interfacing and controlling various peripherals, including LED’s.
In this example, we will see how we have interfaced and LED and how we can control the ON/OFF state of the LED using the EzloPi device.
Welcome to the project demonstration video section. The following video showcases the key aspects of LED ON/OFF, providing a visual walkthrough of its implementation.
Play Video
The following components are required for interfacing the LED using the EzloPi device:
  • ESP32 as EzloPi smart device.
  • LED Light with a current-limiting resistor.
Wiring Diagram
Breadboard
The following connections are made to complete the entire circuit setup.
From ESP32 to the LED:
  • Connect the shorter leg (cathode) of the LED to the GND Pin of the ESP32.
  • Connect the longer leg (anode) of the LED via a current limiting resistor as shown in the diagram above to the IO4 pin of the ESP32.
4. Interfacing the LED with the Web Flasher
Interfacing LED Web Flasher
  1. Log in by using the credentials to your MiOS account.
Login Dashboard
  1. Now click on the Connect Device button and a pop-up window will appear
Connect Device Button
  1. Now, select the COM Port to which your ESP32 device is connected. In our case, the COM3 port is used.
Click Connect.
  1. If you are new to this and it’s your first time configuring, select Create new Device ID and enter the Wifi SSID and Wifi Password.
  2. Now, In the Device Configuration, tab click on Digital Output.
  1. A digital output window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case, we set it to LED.
  • Set Out GPIO to 4.
  • Set the Resistor to PULL UP.
  • Set the default value to low
  • Now Click the Apply button.
  • After clicking the apply button you can see a table of your settings in the device configuration tab.
  1. A window will appear on the bottom left side of the screen displaying “Please press BOOT button while flashing begins.”
  2. Hold the BOOT button down until the next window appears on the bottom left side of the screen which says “Installation prepared. Please release the boot button now.”
  1. After some time this popup will appear saying Device Flashed Successfully! This means that your device has been set up successfully.
5. MiOS App
Google PlayApple App Store
MiOS Installed App
MiOS Login
  1. After successfully logging in, you will be able to see the number of controllers connected such as a lamp, fan, or any other device in the MiOS app. Tap on any controller of your desired ID.
MiOS App Mobile
LED ON
  1. After opening the dashboard, you will be able to see the tile of your connected device.
Here as you can see above, we can see the LED tile. When you tap on it, the LED can be switched ON or OFF and vice versa.
6. MiOS Web Application
Dynamic Dashboard
  1. As you can see in the above figure, the status of the device is indicated whether it is ON or OFF. Clicking on the device tile will toggle the state of the LED.
Bulb On
  1. Clicking on the device tile will toggle the state of the LED.
The LED is turned ON by clicking on the LED button and its status has changed as shown in the above picture.
Buy Components
