Smart lighting solution for all your needs!
In this example, we will be interfacing an LDR (Light Dependent Resistor) module to the EzloPi device. The LDR module senses the changes in ambient light levels based on the surrounding lighting conditions. By interfacing an LDR module with the EzloPi, we can incorporate light sensing capabilities into IoT projects. This allows for intelligent automation and control based on the detected levels of light.
Welcome to the project demonstration video section. The following video showcases the key aspects of LDR digital module, providing a visual walkthrough of its implementation.
The following components are required for interfacing the LDR module using the EzloPi device:
From ESP32 to LDR Module (KY-018):
Click Connect.
