Unlock the power of motion with seamless integration with EzloPi!
Before moving into this MPU6050 example, it is very important to know about the device registration, provisioning and converting the ESP32 device into an EzloPi device along with knowledge of Web Flasher, MiOS Mobile Application for Android/iOS and the MiOS Web Application.
This ESP32 MPU6050 example gives us a clear perspective of how the MPU6050 I2C is interfaced with the EzloPi device.
The MPU-6050 sensor module is an Inertial Measurement Unit commonly referred to as ‘IMU’ comprising of a gyroscope and accelerometer integrated together to form a micro-electromechanical system (MEMS) sensor. This MPU6050 sensor is used for precision tracking and measurement of 3D or 3-axis orientation (Roll, Pitch & Yaw) as it interacts with the outside world. When successfully interfaced with the EzloPi device, we can access the accelerometer and gyroscope data from the MPU6050 module using the serial I2C protocols.
Welcome to the project demonstration video section. The following video showcases the key aspects of MPU6050 3-Axis Accelerometer & Gyroscope, providing a visual walkthrough of its implementation.
The following components are required for interfacing using the EzloPi device:
The MPU6050 I2C wiring diagram is represented as follows:
The following connections are made in order to complete the entire MPU6050 I2C circuit setup.
From ESP32 to the MPU6050 module:
Click Connect
When the touch is being detected then it will appear like the figure on the left. And, when the touch is not being detected then it will appear like the figure on the right.
