													Revolutionize Your Smart Home with Precision Temperature Control!
This example aims to create a seamless and intelligent integration between the KY-001 Digital Temperature Sensor Module and the EzloPi device.
With the user-friendly MiOS mobile and web application, users can remotely access and monitor the temperature information and make informed decisions to optimize energy consumption and enhance comfort. This also allows for intelligent automation, allowing users to set custom triggers and actions based on temperature thresholds values, enhancing energy efficiency and comfortable living.
The following components are required for interfacing the digital temperature sensor module with the EzloPi device:
The wiring diagram of ESP32 32 pin is represented as follows:
From ESP32 (32 pins) to the KY-001 Module:
The wiring diagram of ESP32 38 pin is also represented as below:
From ESP32 (38 pins) to the KY-001 Module:
Click Connect.
