ADXL345 3-axis accelerometer
This example demonstrates the interfacing of the ADXL345 accelerometer module with the EzloPi device, enhancing the capabilities of EzloPi as an IoT platform.
The ADXL345 accelerometer module measures static acceleration due to gravity as well as dynamic acceleration resulting from motion or shock. The ADXL345 is a powerful and highly sensitive 3-axis accelerometer offering precise and accurate real-time motion sensing capabilities in three dimensions (X, Y and Z). The digital output data is accessible through I2C serial communication protocols. By interfacing this advanced sensor with the EzloPi device, you can unlock a world of new exciting applications that leverage motion-based data for smarter automation, security, and control.
Welcome to the project demonstration video section. The following video showcases the key aspects of ADXL345 3-axis accelerometer, providing a visual walkthrough of its implementation.
The following components are required for interfacing the ADXL345 module with the EzloPi device:
  • ESP32 as EzloPi smart device.
  • ADXL345 3-Axis Accelerometer Module with 13-Bit Resolution.
The wiring diagram for ESP 32 pin is represented as follows:
From ESP32 (32 pins) to ADXL345:
  • Connect the GND pin of the ESP32 to the GND pin of the ADXL345 module.
  • Connect the 3v3 pin from the ESP32 to the VCC terminal on the ADXL345 module.
  • Connect the D21 pin from the ESP to the serial data (SDA) pin.
  • Connect the D22 pin from the ESP to the serial clock (SCL) pin.
The wiring diagram for ESP 38 pin is also represented as below:
From ESP32 (38 Pins) To ADXL345:
  • Connect the IO21 pin from the ESP to the serial data (SDA) pin.
  • Connect the IO22 pin from the ESP to the serial clock (SCL) pin.
4. Interfacing the ADXL345 using EzloPi Web Flasher
  1. Now click on Connect Device and a pop-up window will appear
Click Connect.
  2. In the Device Configuration, tab click on I2C.
  1. A Digital Input window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case we set it to ADXL.
  • Select the Device Subtype as the sensor you are choosing. We set it to ADXL345.
  • Set Slave address according to the sensor you’re choosing, In ADXL345, it is 83 (decimal).
  • Set the GPIO pins of SDA and SCL, In our case, we set the SDA to 21 and SCL to 22 with pull-up enabled for both of them.
  • Now Click the Apply button. After clicking the apply button you can see a table of your setting in the Current configuration tab.
  1. A window will appear on the bottom left side of the screen displaying “Please press BOOT button while flashing begins.”
  2. Hold the BOOT button down until the next window appears on the bottom left side of the screen which says “Installation prepared. Please release the boot button now.”
5. MiOS App
Google PlayApple App Store
  1. After opening the dashboard, you will be able to see the tile of your connected device.
  2. Here, as you can see in the MiOS dashboard above, we can see the tiles of x-axis,y-axis, and z-axis all representing their respective readings.
6. MiOS Web Application
Login MiOS
  1. In the above figure, the ADXL345 module connected to the EzloPi device is displaying the respective readings 3-axes (X,Y and Z).
  1. When the position of the sensor is changed, the readings displayed for the 3-axes also vary as can be seen in the above image.
Buy Components
