ezloPi addressable LED Temperature Color Palette
‘Temperature’ color palette (three specific colors are set to the LED) implementation by interfacing the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the ‘Temperature’ color palette using the ‘blink rainbow’ effect in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of ezloPi addressable LED Temperature Color Palette, providing a visual walkthrough of its implementation.
- Jumper wires
Note:
| Addressable LED strip | LED Data (Din) |
| LED Data (Din) | RX2 (GPIO16) |
Click Connect.
5. MiOS Web Dashboard
- A new window will open where you can control your RGB LED.
- On the top right side of the screen under Segment 0, you can set the number of LEDs you want to set for specific effect. In our case, we have set it to from 0 to 10. Here we can also set the reverse direction of LEDs which will apply the effect in reverse (from last LED to first). Also brightness control options are also given.
- Under Effect mode, click on Blink Rainbow to apply this effect. By following the above steps, we can successfully implement a Blink Rainbow effect using addressable LEDs and the EzloPi smart device, enhancing the visual appeal and versatility of your IoT lighting setup.
- Now, on the left side of the screen under Color Palette mode, you can set the color patterns of the LEDs to the effect that has been applied. In this option, we have set the ‘Temperature’ color pattern/palette in which three specific colors are set to the LEDs in the applied effect.
