EzloPi Addressable LED Rainbow Cycle effect
Rainbow Cycle effect implementation by interfacing the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the “Rainbow Cycle” effect in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of EzloPi Addressable LED Rainbow Cycle effect, providing a visual walkthrough of its implementation.
- Jumper wires
Note:
Addressable LED strip | ESP32 |
LED Data (Din) | RX2 (GPIO16) |
5. MiOS Web Dashboard
- Under Effect mode, click on Rainbow Cycle to apply this effect. By following the above steps, we can successfully implement a Rainbow Cycle effect using addressable LEDs and the EzloPi smart device, enhancing the visual appeal and versatility of our IoT lighting setup.
