EzloPi Addressable LED Merry Christmas effect
Merry Christmas effect implementation by interfacing the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the “Merry Christmas” effect in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of EzloPi Addressable LED Merry Christmas effect, providing a visual walkthrough of its implementation.
- Jumper wires
Note:
Addressable LED strip | ESP32 |
LED Data (Din) | RX2 (GPIO16) |
5. MiOS Web Dashboard
- Under Effect mode, click on Merry Christmas to apply this effect. By following the above steps, we can successfully implement a Merry Christmas effect using addressable LEDs and the EzloPi smart device, enhancing the visual appeal and versatility of your IoT lighting setup.
