EzloPi Addressable LED Fire Flicker Intense Effect
Color Sweep Random effect implementation by interfacing the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the “Fire Flicker Intense” effect in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of EzloPi Addressable LED Fire Flicker Intense Effect, providing a visual walkthrough of its implementation.
- Jumper wires
Note:
| Addressable LED strip | ESP32 |
| LED Data (Din) | RX2 (GPIO16) |
5. MiOS Web Dashboard
- Under Effect mode, click on Fire Flicker Intense to apply this effect. By following the above steps, we can successfully implement a Fire Flicker Intense effect using addressable LEDs and the EzloPi smart device, enhancing the visual appeal and versatility of your IoT lighting setup.
