ezloPi addressable LED Effect using specific colors
Breathe effect implementation using specific colors (Red, Green, Blue) by interfacing the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the Breathe effect using specific colors in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of ezloPi addressable LED Effect using specific colors, providing a visual walkthrough of its implementation.
- Jumper wires
Note:
Addressable LED strip | ESP32 |
LED Data (Din) | RX2 (GPIO16) |
4. Interfacing the Addressable LED strip using EzloPi Web Flasher:
Click Connect.
5. MiOS Web Dashboard
Note: Make sure your PC and EzloPi device (ESP32) are connected on the same network to enable this function.
- A new window will open where you can control your RGB LED.
- On the top right side of the screen under Segment 0, you can set the number of LEDs you want to set for specific effect. In our case, we have set it to from 0 to 10. Here we can also set the reverse direction of LEDs which will apply the effect in reverse (from last LED to first). Also brightness control options are also given.
- Under Effect mode, click on Breath to apply this effect. By following the above steps, we can successfully implement a Breath effect using addressable LEDs and the EzloPi smart device, enhancing the visual appeal and versatility of your IoT lighting setup.
- Now, on the top left side of the screen under Color mode, you can set the specific color of the LEDs to the effect that has been applied. In this, we have set the RED color for the first LED option. Also in color mode options are available for brightness of LEDs for all selected ones as well as individual LEDs.
- Now, for the second LED option, we have set the GREEN color from colors mode with the same brightness.
- For the third LED option, we have set the Blue color from colors mode with the same brightness. Now, all the colors have been set to the specified effect.
