EzloPi Addressable LED Color Sweep Random effect
Color Sweep Random effect implementation by interfacing the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the “Color Sweep Random” effect in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of EzloPi Addressable LED Color Sweep Random effect, providing a visual walkthrough of its implementation.
Project Demonstration Video
  • EzloPi device (ESP32-based controller board)
  • Addressable LED strip (WS2812B, WS2811, SK6812, etc)
  • Level shifter module (BSS138)
  • 12V to 5V DC-DC Buck Converter (LM2596, etc)
  • Power supply for the LED strip (5V/12V)
  • Resistor (62 Ohms) (optional)
  • Jumper wires
  • Breadboard for prototyping (Optional)
Note:
  • Ensure that stable output voltages (5V/12V) for both the ESP32 and LED are available.
  • When using a level shifter, including a resistor is optional. Additionally, it's worth noting that some LED strips come with an onboard resistor, making its inclusion optional for effective voltage level conversion.
Addressable LED strip ESP32
LED Data (Din) RX2 (GPIO16)
  1. Under ezloPi on the top left corner, open the drop down menu.
  1. Select EzloPi Addressable LED.
  1. Now, click on Connect Device and a pop-up window will appear.
  1. Now, select COM Port to which your ESP32 device is connected. In our case, the COM3 port is used. Click Connect.
  1. If you are new to this and it’s your first time configuring, select Create new Device ID. Enter Wifi SSID and Wifi password and then click on Flash Device.
  1. A window will appear on the bottom left side of the screen displaying “Please press BOOT button while flashing begins.”
  1. Hold the BOOT button down until the next window appears on the bottom left side of the screen which says “Installation prepared. Please release the boot button now.”
  1. After some time, a popup will appear on the bottom right hand side of your screen saying Device Flashed Successfully!. This means that your device has been set up successfully.
5. MiOS Web Dashboard
  1. After login, click on Platforms then click on Addressable LEDs and press Configure.
  1. A new window will open where you can control your RGB LED strip.
  1. On the top right side of the screen under Segment 0, you can set the number of LEDs you want to set for specific effect. In our case, we have set it to 10.
  1. Under Effect mode, click on Color Sweep Random to apply this effect. By following the above steps, we can successfully implement a Color Sweep Random effect using addressable LEDs and the EzloPi smart device, enhancing the visual appeal and versatility of your IoT lighting setup.
Buy Components
