ezloPi addressable LED Chase Rainbow White Effect
LED Chase Rainbow White effect implementation by interfacing the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the “Chase Rainbow White” effect in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of ezloPi addressable LED Chase Rainbow White Effect, providing a visual walkthrough of its implementation.
- Jumper wires
Note:
Ensure that stable output voltages (5V/12V) for both the ESP32 and LED are available.
When using a level shifter, including a resistor is optional. Additionally, it's worth noting that some LED strips come with an onboard resistor, making its inclusion optional for effective voltage level conversion.
| Addressable LED strip | ESP32 |
| LED Data (Din) | RX2 (GPIO16) |
4. Interfacing the Addressable LED strip using EzloPi Web Flasher:
Click Connect
5. MiOS Web Dashboard
- Under Effect mode, click on Chase Rainbow White to apply this effect. By following the above steps, we can successfully implement a Chase Rainbow White effect using addressable LEDs and the EzloPi smart device, enhancing the visual appeal and versatility of our IoT lighting setup.
