ezloPi Addressable LED Chase Flash effect
Chase Flash (two LEDs flash in secondary color while the rest is lit in primary. The flashing LEDs wander from start to end) effect implementation by interfacing the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the “Chase Flash” effect in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of ezloPi Addressable LED Chase Flash effect, providing a visual walkthrough of its implementation.
- Jumper wires
Note:
| Addressable LED strip | ESP32 |
| LED Data (Din) | RX2 (GPIO16) |
1. First setup your MiOS account by visiting Setup MiOS Account and set up your device/hardware by visiting config.ezlopi.com
- A window will appear on the bottom left side of the screen displaying "Please press BOOT button while flashing begins."
- Hold the BOOT button down until the next window appears on the bottom left side of the screen which says "Installation prepared. Please release the boot button now."
5. MiOS Web Dashboard:
- On the top right side of the screen under Segment 0, you can set the number of LEDs you want to set for specific effect. In our case, we have set it to 15.
- Under Effect mode, click on Chase Flash to apply this effect. By following the above steps, we can successfully implement a Chase Flash effect using addressable LEDs and the EzloPi smart device, enhancing the visual appeal and versatility of our IoT lighting setup.
