ezloPi Addressable LED Chase Color Effect
Chase Color effect implementation by interfacing the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the “Chase Color” effect in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of ezloPi Addressable LED Chase Color Effect, providing a visual walkthrough of its implementation.
- Jumper wires
Note:
Addressable LED strip | ESP32 |
LED Data (Din) | RX2 (GPIO16) |
5. MiOS Web Dashboard
- A new window will open where you can control your RGB LED.
- On the top right side of the screen under Segment 0, you can set the number of LEDs you want to set for specific effect. In our case, we have set it to 15.
- Under Effect mode, click on Chase Color to apply this effect. By following the above steps, we can successfully implement a Chase Color effect using addressable LEDs and the EzloPi smart device, enhancing the visual appeal and versatility of our IoT lighting setup.
